What hitch to pull batwing
   / What hitch to pull batwing #1
firecatf7333
lyons ny
deere
I'm pulling a batwing mower 30 miles with my truck. What hitch will I need to be able to pull it? I have ball hitches, and a circle donut I used for a tractor pull once. Do I need a pointless hitch?
Pics would help thanks
   / What hitch to pull batwing #2
I have seen a couple of different types of hitches on pull type bush hogs.
Most can be pulled with a standard receiver hitch and hitch pin by removing the ball.
Others require a clevis type receiver hitch.
Can you just call who has the cutter to be certain which one you'll need?
The batwing has a clevis style bar/hitch. Can i rem0ve the ball attached t0 my hitch and then the put a pin between the clevis 0n batwing?
   / What hitch to pull batwing #4
Yes, that is the only way to tow it with a truck.
   / What hitch to pull batwing #6
I hope you have a very heavy-duty pickup to pull it with. Batwings are very nose heavy. You will probably be overloading your receiver hitch as well.
   / What hitch to pull batwing #8
you almost got me while I was drinking some iced tea. ;)
Gas Pump Artwork (A55758)
Gas Pump Artwork...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
Toro Greensmaster 3150 Commercial Reel Mower (A56857)
Toro Greensmaster...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
