What hitch to pull batwing
/ What hitch to pull batwing #1
firecatf7333
lyons ny
deere
I'm pulling a batwing mower 30 miles with my truck. What hitch will I need to be able to pull it? I have ball hitches, and a circle donut I used for a tractor pull once. Do I need a pointless hitch?
Pics would help thanks
/ What hitch to pull batwing #2
I have seen a couple of different types of hitches on pull type bush hogs.
Most can be pulled with a standard receiver hitch and hitch pin by removing the ball.
Others require a clevis type receiver hitch.
Can you just call who has the cutter to be certain which one you'll need?
The batwing has a clevis style bar/hitch. Can i rem0ve the ball attached t0 my hitch and then the put a pin between the clevis 0n batwing?
/ What hitch to pull batwing #4
Yes, that is the only way to tow it with a truck.
/ What hitch to pull batwing #6
I hope you have a very heavy-duty pickup to pull it with. Batwings are very nose heavy. You will probably be overloading your receiver hitch as well.
/ What hitch to pull batwing #8
you almost got me while I was drinking some iced tea. ;)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2020 John Deere 6120M (A62180)
2020 John Deere...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
