/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,841
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,842
I had a couple of cracks in mine, and I stitched them back together with a cheap plastic welding gun like this: Plastic Welder Kit Soldering Hot Stapler Bumper Repair Welding Gun 200 Staples | eBay
That is the fastest, but also the crudest way to fix it.
I suggest using the hot iron method to embed some stainless steel screen on the back side. This way, you can continuously reinforce the crack, and have a much stronger, and better looking repair, with only a little more effort.
I have fixed hundreds of bumper covers this way, so I have had a lot of practice. No comparison which method is better.
If you wanted to do the full repair, you could then, "v" out the crack on the front side, and melt some of the filler rod in to the "v". It's pretty straightforward, to refinsh it then, and make it invisible.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,843
@ray66v: Thanks for your message. Before I got and used the "staple gun", I tried welding using a heat gun and ABS filler rod that I had used on other repairs. No luck at all. I do not know what type of plastic the Massey Ferguson fender is made from, but it does not seem to be ABS. But you're right that the stainless steel screen would be far superior to the staples.
I think that you are lucky to have the 3-piece metal fenders on your older GC.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,844
I have a couple of cracks on mine. I drilled holes just past the end of each crack years ago and neither has gotten any bigger.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,845
I saved the piece, but it's not high on my priority list ... Watering again today is!
Filled up in the dark, then started watering ...
Sun was just peaking up when I was over half done with the first of three loads.
We got .65" of rain back on 7/17, nothing since, and it's been HOT out ... Heat index was 107° when I parked Little Baby Fergie in the barn and went inside for a cold shower, the 80° 49% humidity house felt real nice, of course the three cats were inside!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,847
Yard got pretty high while on vacation and a lot of clumps to deal with. My first season mowing with this new GC, mows really well. Have read many places about the crappy steel chute, will be upgrading this for sure.
Had to rig this up and I'm reading nobody has found Gator blades to fit.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,848
one of the good things about a drought is that a normal weekly 3 hr mow job now only takes 100 +/- minutes.
lot less diesel used. sadly same amount of bourbon. meh...problem for another day :)
anyways...guess what I did today with GC2400 and the mid mount mower :)
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A55314)
2023 Kubota...
TANK MANIFOLD (A55745)
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
