/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,411
I have been looking for a switch. What I would like is something that cannot be switched on without effort, for example needing to push in some type of unlocking mechanism before the switch can be turned on. I would also like it to have a light that is on when the switch is on. There are very, very few instances where I would like to disable the seat switch but there are times. But I cannot find such a switch.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,412
I did consider a switch but... a switch can fail or be hit w/o you knowing. I figured me having to actually take a moment to bypass was safer as the bypass could not happen by accident.
like you said, very few times I want the switch disabled, but the few times I need it disabled its safer for me.
when climbing a horse manure pile to rotate it a sudden bump can cause tractor to shut down. pretty friggin dangerous to have no power then.
and when I mount MMM in 2 days I take 30 seconds and switch in play.
it all depends on YOUR needs.
the seat switch don't care about your needs. its there for legal issues.
make it work for you.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,413
That's why I was looking for a switch that you need to do more than just push. For example, I used to work in a factory and the on switches on equipment generally have some safety feature that prevents the switch from being pushed.
Typing this out I was thinking "too bad there no radio shack near me" and I looked and found this RadioShack 12VDC 3P SPST ON-OFF Illuminated Safety Toggle Switch, 20A
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,414
These are heavy duty switches, plus the safety cover
Summit Racing SUM-G3902 - Summit Racing Toggle Switches
Toggle Switch Panel, Premium Metal Material Simple Installation Racing Ignition Switch Convenient To Use For Racing Car For 12V Car Auto
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,415
It would be quite simple to have a switch in protected location ..Using a double pole single throw (DPST) toggle switch you can use one set of contacts to act as seat occupied switch (seat safety switch) and second set of terminals turn on a warning light that seat switch is disabled...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,416
Or just use a momentary bypass switch you hold down when you want to disable.
When you let go, the safety switch is back in the loop.
No forgetting, no checking lights
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,417
I got a bunch of unused dash lights on my GC2400, could easily task one for this. utilize the connectors I just did and if switch fails in seconds I could mechanically be back to switch in play.
may look at that, is an area beside seat hard to accidentally touch that is approx 8" from the switch.
I thought about that prob is the few times I need it disabled I may not be able to hold switch as I rotate around to check stuff.
in all honesty switch will be active most of the time, and when disabled would prob only be 15 minutes once or twice a snowstorm and when tilling only 2 minutes a week on one specific garden I maintain in one specific berry row.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,418
The reason I want a switch to bypass the seat switch has to do with running implements off the PTO where I would like to not sit in the seat. Right now when this is needed I zip tie the switch lever down. It works.
I'm trying to figure out where to put the switch. Not many good places to add a switch on these things. In the end if I put a switch in I'd like it to look like it was meant to be there.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,419
can look at 1725M later today to grab some ideas if you want
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,420
Looked at neighbors GC1725M TLB and think there are 2 spots that would work, they have room under the body for switch base.
this area is below seat and on the edge of the decal there is room under for switch base. I would suspect this would be best spot, not easy to hit it as its out of way but can be accessed easily.
this second pic is right rear behind seat, but I'm not sure how seat swivel for backhoe would work.
2019 John Deere 6175M (A50120)
2019 John Deere...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
Chery Q.A 66" Rock Bucket (A50121)
Chery Q.A 66" Rock...
2017 Kubota U55-4 (A50120)
2017 Kubota U55-4...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
