Shawn T. W.
Platinum Member
- Joined
- Jul 14, 2025
- Messages
- 897
- Location
- SW Missouri Ozarks
- Tractor
- Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
While I'm not expert, I believe that the engineers who designed it limited it's lifting capacity by the amount of hydraulic pressure it can build, and the pistons they feed, ask too much and the bypass relief valve kicks in, I'm fairly sure that they also understand that these tractors are primarily operating off road ...
Unable to lift it to maximum height, is much different than unable to lift it off the ground ... Most people do not travel with the maximum load at maximum height on uneven ground ... Unless they like to figure out how to wake there tractor up from its dirt nap ... !
So basically if it will lift it (and you have proper rear ballast) it is OK. Of course that being said driving down hill with a "full load" at maximum speed, over very rough terrain, and trying to jump the creek
may be a different story, but driving 120' across my lawn with a load of pellets shouldn't hurt anything other than my back loading and unloading them ... I rarely need or use 4X4, and if used properly like the manual calls for on ground that will allow a tire to slide or spin, like ice or mud, I can't see what difference how much weight is on the front would make a difference in wear and tear on the front axle ...
Of course I've only had this little tractor for almost 3.5 years, and creeping up to 700 hours ... Maybe in time I will break it.
