/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,891
spread and tilled in approx 8 cu yds of composted horse manure into garden.
many many trips from pile to garden LOL
once tomatoes are gone another 2 yds to mix in.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,892
easy to clean a deck of push mower with a tractor.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,894
I use my FEL so I can clean under my zero turn too.
No, I don't put it in the bucket. Wish I could though.
I do use a chain to lift the 60" MF2326 mmm to service it. not up in air so I still have to bend but....whatever you do what you can when disabled
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,895
Finally got around to buying the BXpanded Quick-On Back Hoe Bucket Connector, 6 Inch Trencher Bucket, and Back Hoe Ripper. Haven't used the trencher bucket yet but have used the quick-on and the ripper: great.
@Shawn T. W.: Thanks for your photo (attached) on another forum; big help.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,896
Yeah, it really opens up the capabilities of the BH, along with the thumb! 👍
For those that don't know ... The above picture indicates take the red pin and slide it into the slot, then take and pivot the "bucket/ripper" up and slide the purple pin in, takes about 15 seconds!
This was the same day as above picture was taken, ground was frozen 8" deep, neither bucket could penetrate it, used the ripper to loosen it up!
Makes it quick and easy to swap things out ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,897
^^^ I need to buy all of that, dang it's expensive.
Moved my boat with the Massey for the first time to apply some suds. Almost f'ed up, got to improve my hitch for next time.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,898
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,900
Depending on soil conditions, a 6" bucket can be hard to empty.
I have heavy clay soil. And, unless it's bone dry, my 6" doesn't empty well.
I learned to schedule those projects for the driest time of the year. Then, it goes quite well.
The BXpanded design has shallow sides which will help with emptying.
If sticking is a problem, wait for dry conditions.
Shaking the heck out of it, is likely to loosen your bushing's up in a hurry.
UNUSED FUTURE PG72 72" HYD PLATE GRABBER (A58376)
UNUSED FUTURE PG72...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
UNUSED FUTURE 25MM MINI EXCAVATOR ATTACHMENT SET (A58376)
UNUSED FUTURE 25MM...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
LIGHT TOWER (A56857)
Giyi Mini Sweeper (A57149)
Giyi Mini Sweeper...
