What have you done to your Branson today?
   / What have you done to your Branson today?
This appears to be a direct replacement (Identical to mine) suspension seat for the 2004 3520 at
KM 42 Seat & Mech Semi-Suspension | Compact Tractor | Tractorseats.com
   / What have you done to your Branson today? #1,692
I had a heck of a time getting the right belts to fit my tractor too. It took multiple trips to the store. You can't necessarily go by the size printed on the belt (all belts with the same LxW dimensions seem to be the same), and there usually isn't as much room for belt adjustment as you'd like.
   / What have you done to your Branson today? #1,693
Started pulling stumps from dead trees i fell last month. This one is the smallest. Took about 2 hours
The rest is going to be more difficult. They are larger and located on 20-25 degree slope.
   / What have you done to your Branson today? #1,695
How the heck do you get up there?
   / What have you done to your Branson today? #1,696
It is why the Honda is for on the side ;)
Honda's bed, then on the roof, then you are in business.
Dont forget to load all the tools in to the cage before lifting it
   / What have you done to your Branson today? #1,697
Given the current situation in my country for the last couple days and probably a lot more to come with pretty much the upper half of the country burning, today I went to the remote propriety, that is located in the center of of the country, to get my "fire fighting" setup ready to go.
This propriety is located on a small village on the top of a small mountain, so it's very easy to get surrounded by fires once it happens. Last one was 18 years ago, I was like 12 years old. It was quite an experience seeing huge fire balls jump 50 to 70 meters further way and increasing that fire size like nothing.
Here is the situation right now, over 5000 firefighters spread all over the place. More coming from the south of the country to help. Sad part is most of these fires are arson.
And the setup, nothing fancy, probably won't do much but will do something. Just a IBC, small pump and some hose. If I don't use it for me, it will be ready for anyone that may need help. Note the smoke in the air, even thought the closest fire is about 40 miles away.
   / What have you done to your Branson today? #1,698
Good luck, man!, This year is creasy, part of Europe is burning and another is flooded with so much rain.
   / What have you done to your Branson today? #1,699
Thank you! There is indeed some crazy stuff going on.
Looks like we might be getting a little rain Thursday or Friday.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
2010 FORD F-150 (A58214)
2010 FORD F-150...
202481 (A54757)
202481 (A54757)
