What have you done to your Branson today?
   / What have you done to your Branson today? #1,461
So, they changed both crankshaft seals. Interesting why they changed the front one. I guess they know something, otherwise the company would not pay for it. Just a guess.
No, they changed the front differential input shaft seal and the rear main seal. They found the differential seal leak. I did not know it was leaking there.
   / What have you done to your Branson today? #1,462
Interesting if the main was also leaking or they changed it just incase.
   / What have you done to your Branson today? #1,463
Installed OEM rear remotes and hydraulic top link. now waiting for the hydraulic side link to arrive.
   / What have you done to your Branson today? #1,464
I picked up the tractor today and they did not change the rear main seal. They said it was just the front input shaft seal. They also replaced the bearing for it as well.
I suspect it will still leak when it gets hot but time will tell. Also the clutch is catching right at the bottom again so I will have to adjust it again. It tries to grab when fully pushed down. This concerns me as something has to be moving to make that happen. I will keep a close eye on things.
   / What have you done to your Branson today? #1,465
You might ask @Asteral to chime in on this. He’s the parts guy at Big Tex Tractor and he’s very knowledgeable.
   / What have you done to your Branson today? #1,467
So it was the front diff pinion seal leaking and moving all the way back through the driveshaft cover and leaking on the cover plate with the cotter pin?
Wondering if the backplate between the engine and the bell housing is loose and causing issues.
   / What have you done to your Branson today? #1,468
Very well could be. The clutch adjustment issue started at the same time as the leak. Likely they are related. On another note they did pull the inspection plate. I know because they forgot to tighten the bolts and all have backed out with one missing. :ROFLMAO:
I will have to get a bolt to replace the missing one and tighten it up.
   / What have you done to your Branson today? #1,469
Classic. 🤣
2024 CHEVROLET SILVERADO 2500 HD BED (A58018)
2024 CHEVROLET...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2011 GMC Sierra 1500 (A56858)
2011 GMC Sierra...
2017 Ford F-550 Cab and Chassis (A56858)
2017 Ford F-550...
LOT OF AIR GUNS & HAND TOOLS (A58374)
LOT OF AIR GUNS &...
