What happened to the "Delete" button?
Was there a delete button?
  • Total voters
    6
  • Poll closed .
/ What happened to the "Delete" button? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
Or am I just imagining that there ever was one? :D I need to be more careful, if I can't delete the things I never should have posted in the first place. :eek:
The "Poll" is just because I've never done one. ;)
/ What happened to the "Delete" button? #2
The Delete button doesn't appear until you actually post the message. If it is still in edit mode you have to backspace or click and drag to select it and use the delete key.
Edit: I take that back. There DID use to be a delete key. Gone now. Click "edit", select and use keyboard delete key?
Edit2: Yes, that works. (then Save or Cancel)
/ What happened to the "Delete" button? #3
As I recall, it was only in some forums, not all. And I have no idea why some had it and others didn't. And I can't recall which ones did to be able to look for one.
Edit .....
Well, dadgummitall, lookee there!!!!
Maybe that's just because of the MagicModWand?
Hmmm, can't be now that I think of it. I don't have magic powers outside the FP, so .....
Edit; so I am not losing it?
Or at least this isn't another sign that I am. :D
/ What happened to the "Delete" button? #5
Maybe there is a shorter time period that a person can delete a post now?
edit: I just looked for this post.....no delete option.
/ What happened to the "Delete" button? #6
Test for Delete.
Showed up on this one:
/ What happened to the "Delete" button? #8
Checked a post I made earlier today, it has a Delete button:
/ What happened to the "Delete" button? #12
I voted too.....no delete option now though....???? 🔍
Still no delete button but I can still edit.........
/ What happened to the "Delete" button? #15
I don't have a Delete button either. Considering how the World works these days, I'm sure this can easily be seen as discrimination. So expect new movement soon, called "Delete button lives matter". :)
/ What happened to the "Delete" button? #16
I don’t have it.
/ What happened to the "Delete" button? #17
GMC 2500HD 4wd Service Truck (A61306)
GMC 2500HD 4wd...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
UNUSED IRANCH MINI HYD AUGER SET (A60432)
UNUSED IRANCH MINI...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
