What happened to the "Delete" button?
Was there a delete button?
  • Total voters
    6
  • Poll closed .
   / What happened to the "Delete" button? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
Or am I just imagining that there ever was one? :D I need to be more careful, if I can't delete the things I never should have posted in the first place. :eek:
The "Poll" is just because I've never done one. ;)
   / What happened to the "Delete" button? #2
The Delete button doesn't appear until you actually post the message. If it is still in edit mode you have to backspace or click and drag to select it and use the delete key.
Edit: I take that back. There DID use to be a delete key. Gone now. Click "edit", select and use keyboard delete key?
Edit2: Yes, that works. (then Save or Cancel)
   / What happened to the "Delete" button? #3
As I recall, it was only in some forums, not all. And I have no idea why some had it and others didn't. And I can't recall which ones did to be able to look for one.
Edit .....
Well, dadgummitall, lookee there!!!!
Maybe that's just because of the MagicModWand?
Hmmm, can't be now that I think of it. I don't have magic powers outside the FP, so .....
Edit; so I am not losing it?
Or at least this isn't another sign that I am. :D
   / What happened to the "Delete" button? #5
Maybe there is a shorter time period that a person can delete a post now?
edit: I just looked for this post.....no delete option.
   / What happened to the "Delete" button? #6
Test for Delete.
Showed up on this one:
   / What happened to the "Delete" button? #8
Checked a post I made earlier today, it has a Delete button:
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
