What Front loader is this??
/ What Front loader is this?? #21
Sounds like your loader is fine then. It was difficult to tell from the pictures. Just keep an eye on it and keep the bolts tight.
good luck,
rScotty
If you find bolts loosening, consider using some thread locker on them. Red should be fine as the mounting and subframe mounting should not be something you plan to remove unless you have to split your tractor. If you do not want to use red, go with blue!
/ What Front loader is this?? #22
Can anyone tell me what front loader this is? [ photo ]
Bored here, with the lockdown. I expanded your photo and guess what I found. The decal above the front tire is TractorMasters!
In 2003 I got the parts I needed to renovate my badly neglected YM240 from them. Headlight assemblies, a fuel filter assembly (that wasn't quite right until I got the proper element and bowl), dash warning lights, the J-vent under the seat for the transmission, and front wheels because the prior owner of my YM240 had cracked and welded the originals.
TractorMasters was the VN refurb wholesaler, unrelated to Vina etc, who as I described in posts long ago went out of business after honorably taking back too many warranty returns. They had dealers in NorCal, SoCal, and Nevada, apparently in Arizona too.
They had a row of pristine-looking Yanmars (and Iseki etc) to strip parts off of that had failed catastrophically while still under warranty. After a while Lee the manager was away over in VN trying to get the refurb plant to send over better quality. Vannessa his gorgeous sister was doing a great job running the place and another brother was the mechanic. I'm pretty sure all were members of the family that owned the refurb factory in VN.
I also bought my mower and box blade there. Vannessa could have sold snow to the Eskimos. She almost had me talked into being a dealer of the refurbs until I came to my senses. She said they were moving an average 200 refurbs per month.
In 2007 when it appeared they were struggling, I paid $200 for the model of tiller that arrived with all their YM2000's (twin to my YM240). (photo of their tillers).
Then the last time I was in there, disaster. A container on a trailer backed up to their dock with a load of new refurbs that they hadn't unloaded yet had been stolen over the weekend. That must have been a mortal blow. Next time I went there the property was vacant. This would have been about 2008.
Your tractor looks immaculate. With that decal intact, it must have seen little use over the past 15 years.
Oh and what I started out to reply to: Here's a 2004 thread where I posted photos of the subframe under the Great Bend loader on my YM240 (YM2000). It's similar to yours, a little beefier. Vannessa had said their VN factory had bought automated plasma cutters and welders to fabricate loaders, but so far they had only sent over a couple of prototypes. They had put Koyker loaders on everything until then. Possibly your loader came from TractorMasters and they used US-made joystick controllers.
In 1973 I got the parts I needed to renovate my badly neglected YM240 from them. Headlight assemblies, a fuel filter assembly (that wasn't quite right until I got the proper element and bowl), dash warning lights, the J-vent under the seat for the transmission, and front wheels because the prior owner of my YM240 had cracked and welded the originals.
California, Wow that is a cool story. Man you have a wealth of information! I think that tractormaster sticker is the only thing I haven’t touched on this tractor, I have put a lot of work in this tractor, sometimes I wonder if it’s worth it,I do like how it’s turned out though. One good thing about these tractors is they are super simple to work on. The only thing I haven’t touched on this tractor besides that sticker is the transmission. I have freshened up the engine,rings, Rod bearings, head work,redid the front end loader , In the pictures you can see the top pivots don’t know what they’re called. as you can see I have cut them tubes off like 4 inches from the end and then made new ends with bushings in them, I didn’t have any 2x4 tube,so I cut some flat stock took some 1-1/4DOM tube,Machined them for Zerk fittings and some bushings and then on the other pivot points I’ve drilled out and welded in hardened washers. Had to take the three point hitch apart as the control valve was not working right,was able to fix it without spending any money. So this tractor was well used.
/ What Front loader is this?? #24
Bah typo! I bought the YM240 in 2003. I edited my post but I see my error is visible in your quote.
Anyhow - Your YM2210 is a great model, with the Powershift. Enjoy!
Thank you sir,I will.
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
