What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #21
I use mine to move pallets (obviously), my 30 gallon fuel tank, round bales, move anything in/out of the loft in my barn, that's all I can think of now but I know there's more.
   / What else do you do with forks besides lift pallets? #22
Move Cattle Panels.
10' long.
12' long.
16' long.
Had to add the winch for extra counterweight. :thumbsup:
Pictures taken 9/5/2013
   / What else do you do with forks besides lift pallets? #23
I seldom need to lift a pallet, but the forks stay on there more than the bucket does these days. Moving the picnic table around is easy, moving things for my neighbor's and myself. Useful cutting firewood, keeps my saw outta the gravel.
   / What else do you do with forks besides lift pallets? #24
Picking up logs, Picnic Tables, Pallets, Holding up Mower Decks for cleaning, Holding up deer for cleaning, Putting up Deer Stands, POrtable workbench for wife when gardening, unloading items bought at auctions, cleaning out gutters, the list goes on and on. Buy em
   / What else do you do with forks besides lift pallets? #25
Move Cattle Panels.
Yes, yes. I didn't think to list that. They are GREAT for moving cattle panels and tube gates. If the cows knock a fence down in a remote spot, I use the forks to haul the panels and create a temp fence with the panels until I can get to fixing the fence.
   / What else do you do with forks besides lift pallets? #26
I turned my compost pile with the forks today. Works ok.
   / What else do you do with forks besides lift pallets? #27
Back in June of 2005 when I put this together, it was the only loader that I had.
Hauled a lot of brush and dead trees, made some big brush piles. Lift height to the pins is 9' 3".
Loaded the 16' deckover with fresh cut cedar trees.
Unloaded them at the burn pile.
An addition to the forks.
   / What else do you do with forks besides lift pallets? #28
I was thinking about this thread over the weekend. I used my tractor forks to spray my lawn.
Its a little pull-behind 15 gallon Fimco sprayer. I plugged it into a battery maintainer port that I added to power the pump.
   / What else do you do with forks besides lift pallets? #29
I use my forks almost daily and I haven't moved a pallet in months. I have a slip on trailer ball I put on the forks and I use that all the time moving trailers and I use the forms to move pipes, gates, round bales, implements, my dumpster,etc
   / What else do you do with forks besides lift pallets? #30
Using the fork tips to knock the dirt off of the root ball.
Using the forks to carry the tree to the burn pile. :thumbsup:
This has really turned into an informative thread. Pallets seem like the last thing you use forks for.
   / What else do you do with forks besides lift pallets? #32
I use mine on the jobsite to move lumber closer to where it will be used
   / What else do you do with forks besides lift pallets? #33
My biggest use is for firewood - hauling the bucked logs in, holding the logs for cutting up off the ground, and then bringing the wood to my basement in the winter. But I find all sorts of things to lift with them - since I use them on the 3 pt i put various modified wood crates to use as carryalls. Just the other day I lifted my dump rake and supported it while I pulled the wheel and greased and tightened the bearing. I do not know how I got by without them. Oh yes - once in a while I move a skid.
   / What else do you do with forks besides lift pallets? #34
Moving a roll of sod with the block forks. :thumbsup:
   / What else do you do with forks besides lift pallets? #35
I realize this is an old thread, but no reason to start a new one. A heavy set of forks can pop very large rocks out of the ground with minimal ground disturbance! And then can move the rock to the location of your choosing!
   / What else do you do with forks besides lift pallets? #36
Having a grapple reduces the possible uses for forks, but they are still useful. I use mine for unloading pallets, moving stumps, moving large rocks, unloading stuff off the truck, and if you don't have a grapple they are decent at moving brush.
View attachment 448176View attachment 448177
Great picture and that's a good use for forks. I'm on the lookout for a used set now.
   / What else do you do with forks besides lift pallets? #38
Must have missed this one during plow season. I U-bolt a 12'-16' 4x4 onto one tine and it makes a great boom pole for small trusses or lighter hanging. I use a jet sled to blow wood chips into and chain it onto the forks, then can cart 2-3 bucketloads at a time, in real time, without having all the chips lost/blown/spread. I put chain hooks on it, and its a much better implement shuttle set-up than chains on the bucket, or using pallets. I intended to "palletize" everything, but they are more trouble than help as they age. Oh right--you can unload packaged goods on pallets with them too!
   / What else do you do with forks besides lift pallets? #39
Used ours today to lift/slide our new outdoor wood boiler into place.
I have one homemade fork frame and three or four combinations of forks, lifting bars etc that pins onto the frame. Today the forks were 14" long (normally used to carry frames of firewood) yesterday they were 8' long when I wanted to lift the raft out of the lake. Tomorrow I will have the 3' forks on for moving logs around.
I also have the ability to slide a 2" draw bar into the frame. One draw bar is five feet long with lift hooks on the end for setting heavy stuff in place....another has a winch on it.
   / What else do you do with forks besides lift pallets? #40
2018 CATERPILLAR D6K2 XL CRAWLER DOZER (A60429)
2018 CATERPILLAR...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
24in pin on tooth excavator bucket (A61306)
24in pin on tooth...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
