What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #21
I use mine to move pallets (obviously), my 30 gallon fuel tank, round bales, move anything in/out of the loft in my barn, that's all I can think of now but I know there's more.
   / What else do you do with forks besides lift pallets? #22
Move Cattle Panels.
10' long.
12' long.
16' long.
Had to add the winch for extra counterweight. :thumbsup:
Pictures taken 9/5/2013
   / What else do you do with forks besides lift pallets? #23
I seldom need to lift a pallet, but the forks stay on there more than the bucket does these days. Moving the picnic table around is easy, moving things for my neighbor's and myself. Useful cutting firewood, keeps my saw outta the gravel.
   / What else do you do with forks besides lift pallets? #24
Picking up logs, Picnic Tables, Pallets, Holding up Mower Decks for cleaning, Holding up deer for cleaning, Putting up Deer Stands, POrtable workbench for wife when gardening, unloading items bought at auctions, cleaning out gutters, the list goes on and on. Buy em
   / What else do you do with forks besides lift pallets? #25
Move Cattle Panels.
Yes, yes. I didn't think to list that. They are GREAT for moving cattle panels and tube gates. If the cows knock a fence down in a remote spot, I use the forks to haul the panels and create a temp fence with the panels until I can get to fixing the fence.
   / What else do you do with forks besides lift pallets? #26
I turned my compost pile with the forks today. Works ok.
   / What else do you do with forks besides lift pallets? #27
Back in June of 2005 when I put this together, it was the only loader that I had.
Hauled a lot of brush and dead trees, made some big brush piles. Lift height to the pins is 9' 3".
Loaded the 16' deckover with fresh cut cedar trees.
Unloaded them at the burn pile.
An addition to the forks.
   / What else do you do with forks besides lift pallets? #28
I was thinking about this thread over the weekend. I used my tractor forks to spray my lawn.
Its a little pull-behind 15 gallon Fimco sprayer. I plugged it into a battery maintainer port that I added to power the pump.
   / What else do you do with forks besides lift pallets? #29
I use my forks almost daily and I haven't moved a pallet in months. I have a slip on trailer ball I put on the forks and I use that all the time moving trailers and I use the forms to move pipes, gates, round bales, implements, my dumpster,etc
   / What else do you do with forks besides lift pallets? #30
Using the fork tips to knock the dirt off of the root ball.
Using the forks to carry the tree to the burn pile. :thumbsup:
iDrive TDS-2010H...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2015 FREIGHTLINER...
2023 Spartan RTHD Zero Turn Mower (A59814)
2023 Spartan RTHD...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
Compressor (A55973)
Compressor (A55973)
