Do you think I will be able to lift this? Kubota M7060
   / Do you think I will be able to lift this? Kubota M7060
I recently received a crate of solar panels that weighed 2298 lbs. my MF2705E loader with forks is rated at 2300 lbs. I can report that I was able to raise it only a few inches off the truck bed so that the truck could move forward and the load lowered. It’s imperative that you have substantial weight on your 3 point hitch for this to work otherwise the tractor could easily tip forward (I had a heavy Gannon box blade).
Yeah I will, I have a heavy blade I use for counterweight.
   / Do you think I will be able to lift this? Kubota M7060 #22
Think outside the box. You don’t have to lift the hole thing at once. Grab the end drag in part way out. Set it on the ground. Drive tractor to the side lift the end that is still on the truck and have him pull out. That way you don’t have to lift the whole thing at once.
   / Do you think I will be able to lift this? Kubota M7060 #23
Any way you can get in touch with the company that is going to deliver your material with a lift gate, this would solve your problem.
How would you get a 10' wide pallet on a lift gate that at best is 8'x8'.
ericb2400; how do you propose to prevent damage to the product when sitting one end on the ground?
   / Do you think I will be able to lift this? Kubota M7060 #24
It’s on a pallet isn’t it. Same as lifting from the end. I would hope it’s not hanging 3+ feet over 2 sides of a 4 ft pallet at 10 ft wide.
   / Do you think I will be able to lift this? Kubota M7060 #25
Pair of tractors is my suggestion! While rated for it, my M7040 probably wouldn't pick it up as the hydraulics seem to be weaker than the advertised amount, though I have never tested it against the actual specs to confirm that.
Due to the length of the pallet overhang, you probably aren't going to get a good straight shot on the pallet anyway, so having another tractor on site is a good idea. Also, I would seriously consider having at least a pair of slings to pick up the ends with, in case the building overhangs the pallet and the driver has to pull forward, or you have to slide it out. Slings do a lot less damage than forks to the building in the case of them slipping as you pull the building out of the trailer.
Ask the delivery company if an open side or a flatbed trailer is available for this delivery! Also, look at the pallet ON THE TRUCK before you ever touch it with your tractor, as forklifts at LTL terminals aren't made to handle excessive lengths that don't fit a standard pallet, and there is a good chance that they shoved it from one end or the other during the load/unload process. Also remember, it will have been handled several times, because the LTL companies use a HUB to accept all deliveries, and then transload them to the trailer going to your ZIP Code.
Good luck, David from jax
   / Do you think I will be able to lift this? Kubota M7060 #26
I don't think I would risk lifting that much weight if you need to lift it high up. Tractors with FEL's are for sure not forklifts. What you don't want to do is die.... At least not because your tractor flips over on you, or your loader collapses, etc. I wonder what it would cost to rent a forklift for an afternoon?
   / Do you think I will be able to lift this? Kubota M7060 #27
i thought delivery freight can unload for a surcharge? at least that's the way freight delivery has worked for me. i would not attempt to unload w/your machine, mine's the next size up & i wouldn't consider given potential product damage
   / Do you think I will be able to lift this? Kubota M7060 #28
The pallet won’t fit on a lift gate which would eliminate the vast majority of for hire trucking. You can’t readily hire a truck equipped with a moffit forklift. Freight trucks are more concerned with the area it takes up especially when it’s a light load anyway so asking them to ship it on separate pallets won’t be a free option.
   / Do you think I will be able to lift this? Kubota M7060 #29
`makes sense, haven't had much freight delivered, tailgate delivery has been an option. good luck to OP on his delivery choices
   / Do you think I will be able to lift this? Kubota M7060 #30
To the OP on this, if you're going to use the Kubota, know that the loader cylinders have two positions. One is for the most height and one is for the greatest lifting power. Look in the owner's manual.
With mine on the strength position, I can just barely lift a ton pallet.
   / Do you think I will be able to lift this? Kubota M7060 #31
I'm reading this and thinking to myself about it...
Here is my opinion for what it's worth..
First off Farmtek never ships assembled buildings they all come in pieces.
I know as I erected a 46 wide x 15 foot high x 96 foot long truss arch barn from them, actually a pair of them and they both shipped on various sized pallets and skids and boxes but nothing was assembled. We had to put them together, anchor the trusses with screw in ground anchors and install the rip stop multi layer roof. We put ours up with the truss bases screwed to 4 x 12 x 20 foot long .40 retention planks and each plank was joined at the ends with 1/4" steel flat plate joiners.
Your building will come completely unassembled and either you or your crew or a Farmtek contractor will erect it.
I used my Kubota M9 loader to position the trusses, they are not that heavy. My big issue was the 14 foot high x 10 foot wide roll up overhead door that had to be fastened to the 4 x 6 pressure treated header that the end panels attach to. Had a hell uva time with it because I* lacked the reach on my loader to set the door. What I had to do was sit the door assembly on a round bale that I sat vertically on my forks and had a willing participant ride up with it and secure the door to the PT wood end frame, the end frame sat in post hole drilled holes I drilled 4 feet deep with my PHD and filled with Quickcrete. It's a job erecting one and you have to make doubly sure the trusses are not only spaced properly to accept the purlins and the center tube but you have to make sure the bases are parallel and square.
If you need any assistance or advice, shoot me a PM. Like I said we (my buddies and my wife and me) put up 2 of them.
In fact the roof ripped on one this spring and I had to order a complete new top from Farmtek to the tune of 11 grand. My farm insurance covered it... Lucky me. Still had to install it. Took 6 stout guys with ropes on a calm day to get it on.
I keep all my farm equipment in one, hay tools, tractors and implements and the other houses my International Eagle conventional and my 42 foot Timpte grain trailer and our RV.
Used to keep round bales in it as well but now my cistomer picks up rounds out of the field and buys them all so I don't keep any inside today.
They both are sitting on an engineered sand base with a retaining wall on the low side. Had a local contractor come in and laser grade and backfill the space.
If you want pictures, I can send them to you or if you want advice, just PM me. I'm extremely familiar with Farmtek buildings.
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A60432)
UNUSED AGT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Chevrolet Express Cargo Van (A59230)
2021 Chevrolet...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
