What do you think?
/ What do you think? #1
Tractorgirl
West Virginia
Mitsubishi MT3201 4WD
Okay, my hydraulic filter light came on my Mitsubishi 3201D.
The engine began to bog down even on the most even ground and when lifted, the brush hog would just sink to the ground. There doesn't seem to be a leak so what else should I be looking for? /forums/images/graemlins/confused.gif I've ran the tractor about 20 hours but would that be enough to clog a filter? It doesn't seem to me that it should be but then again, I'm just learning about fixin' tractors. Any suggestions and help would be appreciated!!!
Thanks guys! <font color="red"> </font>
/ What do you think? #2
The trans screen is not cleaned by most importers or dealers. Check that. It is in line before the actual filter.
/ What do you think? #3
I agree with Reed. Check and clean the pickup screen. I also drain ALL the hydraulic fluid from tractors when I get them. You wouldn't believe the moisture and other gunk I get out of some of them. Around my area that moisture turns into a sludgy goo similar to the consistency of thick hand lotion when the weather gets cold. Hard to get that through the pickup screen too.
Check the pickup screen, if its covered in dirt and crud, I'd drain the fluid and replace it too. Cheap insurance to long hydraulic pump and valve life.
Nick
/ What do you think? #4
Tractor girl
That happened to me on a mitsu 3201-D also /forums/images/graemlins/shocked.gif
I changed the fluid & filter, and the light went out.
The filter is located in front floor by the foot throtle pedal behind the side panel.
filters are 12.00 at napa, do the fluid while youre at it too!
Ernie <><
Thanks guys!!! Will try to implement your suggestions this weekend.
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
Kuhn FC400RG (A60462)
