What do you think fits my needs?
/ What do you think fits my needs?
I do get an adequate snowfall around here. How do you find the JD 4010 to be at tackling the difficult tasks? My tendency at the moment is to think a bit bigger, say maybe a JD 4115. My preference at this point is definitely for a machine with a hydrostatic transmission.
/ What do you think fits my needs? #22
I think your optimum tractor would be 25-35 hp, hydro, with R4's, 4wd. FEL would be nice if within budget. Required equipment would be 7 ft rear blade (grading, snow removal) and 5 ft rear finish mower. You can save $$ buying used from a private owner but be sure to check the machine carefully. Many other places on this site will tell you what to look for concerning used tractors. You are looking at the right brands for sure but they all have good resale which will cost you initially.
/ What do you think fits my needs? #23
You state mowing would be a main function of the tractor. Are you mowing more than your 1.5 to 2 acre lawn? If not, I would go with anything larger than a B series Kubota and then I would go with the MMM instead of the rear. I am quite happy with my B-7800 but with the FEL and mower, it would be out of your suggested budget. I have 6.5 acres and use mine for basically everything you described although I keep about 3 acres or so mowed. I plow a 220 foot driveway plus the turnaround, mow, cut trails in, move larger rocks (I'll leave the Buick size rocks to a more capable machine), drag trees, use tiller for garden and also maintain the driveway.
Good luck and take your time.
/ What do you think fits my needs? #24
MouseDoc
First, I think it is cool how you have tried to reply to everyone's posting individually. Very admirable... but you'll kill yourself doing that on this site. These guys will run a thread for 10 pages. /forums/images/graemlins/wink.gif
Second, I have a tractor for you! It is a Kubota B7800, Mine!
It is a light weight CUT. 30HP. Falls right in your price range too. See my classified add on this site. If you don't buy mine. Take a look at a new one at least or a Mahindra.
Thanks, nice summation. Do you have any particular recommendations?
I anticipate ending up with 2 acres of lawn, possibly a bit more, but definitely less than 3 acres of lawn. I think there are several B models that may be a good fit, the B7800 being one of them. Do you plow with the FEL or a blade?
Thanks.
Thanks for the compliment and the info. I’ll give your B7800 some consideration. Why a Mahindra?
/ What do you think fits my needs? #28
You've gotten some really good advice and have begun seeing some of the opposing camps. On the right there is the "bigger is always better" crowd. On the left is the "don't spend a fortune for a tractor capable of doing a big job that only has to be done once" crowd. I'm a centrist, leaning slightly to the right...but then I have 155 acres to care for.
Back in the days when all I worried about was the 7 acres of meadow surrounding my house, plus a couple of trails in the woods, I was perfectly happy with my little B1750. Not much lifting capacity on the loader, but it was light and nimble, mowed like a son of a gun, and did a decent job moving snow which we get a lot of here in northern VT. I had a lot steeper slopes though, at 22%, which was one reason I traded up. I'm also a fan of R1 aggies, but in your case it sounds like R4s would do just fine.
Orange, green, blue, red. Take your pick and try them all out on the dealers' lots. Some dealers will even let you try one at home if they feel you're definitely going to buy something from them. Or they'll rent you a tractor with the rental fees going toward the purchase price.
And that's a nice segway into my last point. Don't just shop for a tractor, shop for a dealer. You're going to be spending a lot with the dealer, and probably have a few service calls in the course of your ownership, so choose one you feel good about. If I liked a Deere and a Kubota equally, the deciding factor would be the dealer.
Happy hunting! Pete
/ What do you think fits my needs? #29
I currently plow with the FEL but I'm thinking about getting a 72" or 84" rear blade. We don't really get that much snow. Using anything on a gravel drive can be tricky until you get the hang of it.
If you don't go new, I would definitely look for a used one from a private owner. I got my first tractor from a private owner and then a few years later traded up to a new B-7800.
Good luck
/ What do you think fits my needs? #30
Hi mousedoc,
Welcome to TBN. The guys have given you some excellent advice, I just thought I would chime in because we ahve about the same amount of property. Of my 10 acres, 8 acres is open meadow that requires mowing a few times a year. I use a 32 hp Massey 1040 FWD with a front loader and it handles its tasks well. I dont think you would want anything too much smaller than 30hp. You definitely want a front loader, you will always find a use for it and it will never get old /forums/images/graemlins/grin.gif I bought my machine for $6000 a little over 2 years ago and its treated me very well so far. Good luck in your hunt.
scotty
/ What do you think fits my needs? #31
i don't think all of the advice given was good. the tractors given by name & model would not be a good choice for the cost. there r many good tractors out there. for a little more money can (lift & breakout force) all most twice as much as the 1's mentioned. so u should check out the spec's of the tractor. the 1's mentioned r really a glorified garden tractor. and all brands have that type of model, just make sure that is what u want and u r not undersized.
/ What do you think fits my needs? #32
One thing you'll find a lot of here is free advice, most of it good. The next most common thing is opinions, few of which are exactly the same. Everyone has preferences for this reason or that one.
Speaking as a guy with a few tractors behind or beneath me who has been trying to narrow down a choice for quite a while now, I encourage you to take your time, try a lot of things on for size (literally), drive as many as you can, try the pedals and hand controls for ease of operation, and think if you and the tractor will still fit each other in 5, 10, or 20 years. If you buy a new one, it can easily last that long with good care. I have two that are in the 30 year old range, one a mower and the other a tractor.
Tires and transmissions are a big source of discussion here, with good reasoning and strong opinions on all sides.
Using tires as an example, I finally decided that I need ag tires because I use the tractor in the woods and barnyard and for driveway maintainance, but don't mow with it. Traction is at a premium, especially this time of year.
You might want to keep your JDs, at least one of them, as a dedicated mower and get a CUT for other work. Either R4s, which look tough and macho, or R1s, which don't look so tough but offer better traction, will be much harder on your lawn than turf tires on a smaller mowing tractor. It depends on how manicured you want the lawn to be. If mine is more or less green and short enough to not hide a small dog, it's fine. /forums/images/graemlins/laugh.gif Other guys want a putting green for a front yard.
The best advice I can offer is to spend a lot time reading here and thinking about how you'll use the tractor. Personally, I'd check with anyone you see using a tractor in their yard and ask about how they like it, what they do with it, how they like the dealer, etc. As has been said, the name brands are going to cost more, but have a better track record in general. There are examples of the off-brand machines doing exceptional work, but most here tend toward the higher recognition, higher price, somewhat more feature laden hardware.
For most of us, these are tools that serve as big toys, or toys that are justified by being used as tools. Just like hammers, you can buy a cheaper one (cast iron head and wooden handle) or a very expensive one (ergonomically designed head machined from unobtainium alloy integrally fused to a guaranteed forever shock absorbing polymer handle). They'll both drive a nail equally well, so it's up to you to decide which one you want. Or just get a bunch of power nailers instead! /forums/images/graemlins/grin.gif
Incidentally, not too long ago I saw a hammer in a catalog for $239.00! /forums/images/graemlins/shocked.gif
Oh yeah, the other thing the guys here are good at is vicariously shopping for tractors. We love to help you spend your money, the more the better.
Over the years I’ve learned to try and use the right tool for the job… as much as possible. I’m well aware there is more to a tractor than just hp. Heck, I’m plowing snow with an 8hp JD110 Garden tractor. It’s managing to get the job done, but it’s clearly undersized.
I couldn’t agree more, all things being equal, the deciding factor would be the dealer.
New is always nice, but a well cared for used machine doesn’t worry me much.
Thanks for the input.
I tend to look at all the advice as valuable, some just more applicable to my situation. It all stems from the experiences well meaning people have had with their machines.
I suspect this will be the last tractor I buy, and have no doubts about a tractors ability to last for 30 years or more with proper maintenance. Heck, I’ve had the 110 about 31 years now, all without a single trip to the dealer, and still runs like a champ.
As far as keeping my JD’s, I’ve already given some thought to keeping the 318, and most likely will (if possible). It’s in nice condition with about 575 hours.
A $239.00 hammer huh, well I guess that might be for the person driving around in the $500,000 plus Ferrari Enzo.
Thanks for all the advice.
/ What do you think fits my needs? #38
</font><font color="blueclass=small">( Thanks for the compliment and the info. I’ll give your B7800 some consideration. Why a Mahindra? )</font>
Why a Mahindra? Because for the money I don't think there is a better tractor made. I was about to buy one myself when I found a good deal on my Kubota here locally. I don't have any Mahindra dealers close either.
If your familiar with the Deming prize for quality, Mahindra is the only tractor Manufacture ever to win this prize. They have a 98% satisfaction among buyers. They are a great little tractor. Go to the Mahindra forum on this site and ask those guys if they would buy again.
The only thing that Kubota has on the Mahindra, IMO, is the Kubota diesel. I personally don't think there is a better diesel engine than the one Kubota makes. My opinion.
In your price range, you will get more tractor if you buy a Mahindra than if you buy a well known brand of tractor. The only downfall with Mahindra is resale value. Since they are not well known in the states, you would have more trouble selling than you would a Kubota or JD. So only buy one if your certain you want to keep for a long while.
/ What do you think fits my needs? #39
</font><font color="blue" class="small">( i don't think all of the advice given was good. the tractors given by name & model would not be a good choice for the cost. there r many good tractors out there. for a little more money can (lift & breakout force) all most twice as much as the 1's mentioned. so u should check out the spec's of the tractor. the 1's mentioned r really a glorified garden tractor. and all brands have that type of model, just make sure that is what u want and u r not undersized.
)</font>
Linpat,
For you to make a comment like that I'm thinking maybe you have never owned a CUT like some of the ones mentioned above. I've owned both heavy garden tractors and a CUT and I can tell you that the difference is astounding. My B7800 is the most amazing piece of machinery I have ever owned. It has done things that a garden tractor could not even think of doing. Most of the guys on this site will tell you the same about their CUTs. If your talking about the Kubota BX then maybe it is a little light. But as long as he stays in the B series Kubota he will be fine.
/ What do you think fits my needs? #40
)</font>
Linpat,
I cant see how you can make a statement like that!!! My MF 1040 weighs in at a hefty 3800 lbs without the loader. Loader goes another 1200lbs bringing the total up to 5000 lbs without any implement. That 32hp diesel could pull a house down. I own a 1982 12 hp Wheelhorse C-125 garden tractor, and if I hooked a half dozen of those garden tractors to the drawbar that Massey would pull them all over my property!!! I think you need to reavaluate that statement.
scotty
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
YALE VERACITOR 50XV STRAIGHT MAST FORKLIFT (A64279)
YALE VERACITOR...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
