What Do You Do With Your Waste Oil?
   / What Do You Do With Your Waste Oil? #121
agree. and i wonder why the epa is ok with asphalt. not much different than motor oil. id spread my old oil on my roads, but my calif neighbors would turn me in. they actually called the cops on me for target practicing a month back. the cops didnt even come by my place. i only heard about it thru a local volunteer.
they need to move back
   / What Do You Do With Your Waste Oil? #122
Those waste oil heaters cost big bucks and if you let other guys put their waste oil in a barrel you are going to burn watch out as they don't just dump waste oil and next thing you are cleaning out or replacing parts on your burner.
I have seen prices from $3150 to $6850 and parts ain't cheap either. I will stick with a wood stove and soak the chunks of wood in oil and then burn them and also on a fire pit can burn some oil there also.
willy
   / What Do You Do With Your Waste Oil? #123
When I had trucks, I would dump it in the fuel tanks and burn it, ten gallons of oil that I didn't have to get rid of, and ten gallons of fuel I didn't have to buy.
Since they're gone, I take it to TSC. Just took the last of a 55 gallon drum full to them on Monday.
   / What Do You Do With Your Waste Oil? #124
Blame the CA refs on city hall but what about ag lobby? At the end of the day, you can’t use a oil based solvent to clean the oil off your paver. You need to use a citrus cleaner to support the California citrus farmers. Remember that when you buy Simple Orange hand cleaner. Yeah, I do like it but I thought it was ironic cleaning the oil with citrus since it’s oil in the first place. Gotta live lobbyists.
   / What Do You Do With Your Waste Oil? #125
willy
Most waste oil burners worth their salt have built in separators in them to remove contaminants from the waste oil. My Clean Burn does. Never had an issue with mine in 10 years, other than cleaning the oil injection nozzle every fall. Yes, the initial cost was high but the ROI has made it 100% worth the initial cost. It burns everything except antifreeze. Gear oil, crankcase oil, brake fluid, any petroleum based product.
Nothing beats a warm tractor shop on a cold winter day and no particulate emissions coming on the vent pipe.
All you are doing by soaking wood in used motor oil and burning it is contributing to pollution. Nothing more and a whole lot less.
   / What Do You Do With Your Waste Oil? #126
It is not a good idea to put used motor oil in any contact with the ground. It will wind up in the water table where it will pollute incredible amounts of water. You'll also eventually drink it. I recall a study from Maine that a very small amount ( less than an oz?) of used motor oil would pollute around 10,000 gallons of water. Other things I read said 10 times that amount.
Now, I'm no tree hugger and have no problem with most things but don't want to drink used motor oil with all the fluids and heavy metals it contains. It's OK if others want to do it but do it straight from the container. In water it also is consumed by animals that we depend on from critters and birds to dogs, fish and farm animals. I like to fish.
Rethink used motor oil for any application where it can contact the ground. There are suitable substitutes--still oils--that work just the same and don't cause the drinking water issue.
   / What Do You Do With Your Waste Oil? #127
What we learned at school, more than 40 years ago, one drop of oil ruines a full bath tub of water.
   / What Do You Do With Your Waste Oil? #128
Did you run it thru any sort of filter before you put it in the fuel tanks? I would think that all the gunk in the used oil would plug up your fuel filter pretty quick.
   / What Do You Do With Your Waste Oil? #129
Roadway Express has done just that for decades. The fuel filters are less expensive to change than getting rid of used lube oil.
   / What Do You Do With Your Waste Oil? #130
Put your used oil in your truck/tractor nowadays. Then tell us what's cheaper.
   / What Do You Do With Your Waste Oil? #131
I don't, I burn it in my waste oil furnace. I own a Clean Burn. Just stating what Roadway (YRC) does with theirs, nothing more.
   / What Do You Do With Your Waste Oil? #132
That should only be done if you know that your waste oil is compatible with the DFP or other emissions equipment on your machine. Some oil is NOT compatible and WILL "poison" the DPF.
Aaron Z
   / What Do You Do With Your Waste Oil? #133
Yes, I had a 3/4" hydraulic couplers adapted to the drain plugs on the CAT engines, and a hose with a female coupler that went to an air operated pump that pushed it though an engine oil filter and into one of the fuel tanks. The only oil I had to dispose of was that was left in the used engine filter.
After a few oil changes I would cut the pump filter apart and check it for debris. Never found anything whatsoever. After all, it's being filtered continuously in the engine, so it should be clean or you have a big problem.
   / What Do You Do With Your Waste Oil? #135
I put it in 55 gallon barrel than use a pump to put it in 5 gallon containers usually def or 5 gallon buckets when the barrels full, finally it ends up at the recycling center where they take it for free. When I plowed snow for the county we used waste oil liberally on the chains for the salters used a one gallon sprayer that worked pretty good.
   / What Do You Do With Your Waste Oil? #136
Use it to burn my garbage and for dust control in the driveway.😂😂😂😂
   / What Do You Do With Your Waste Oil? #138
The county can spray 1,000's of gallons on the road and dump crushed rock on top "oil & chip"
   / What Do You Do With Your Waste Oil? #139
I don't worry about oil on the ground as we have a
slab of granite 6 ft deep all the way across out property
8 acres. Dirt is 8 ft deep one side and about 3 ft on the other side. When I was in Wisconsin would take the drain pan full of oil get the hose and some basic H pour some basic H in the pan and run the hose and you could run your hand over the grass where I did this and you would not get any oil on your hand.
willy
   / What Do You Do With Your Waste Oil? #140
I'm obviously joking........but I did use a few jugs to treat the posts of my decks, LOL
UNUSED RAYTREE RMLL60-60" HYD LAND LEVELER (A60432)
UNUSED RAYTREE...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
