What Do You Do With Your Waste Oil?
   / What Do You Do With Your Waste Oil? #131
I don't, I burn it in my waste oil furnace. I own a Clean Burn. Just stating what Roadway (YRC) does with theirs, nothing more.
   / What Do You Do With Your Waste Oil? #132
Roadway Express has done just that for decades. The fuel filters are less expensive to change than getting rid of used lube oil.
That should only be done if you know that your waste oil is compatible with the DFP or other emissions equipment on your machine. Some oil is NOT compatible and WILL "poison" the DPF.
Aaron Z
   / What Do You Do With Your Waste Oil? #133
Did you run it thru any sort of filter before you put it in the fuel tanks? I would think that all the gunk in the used oil would plug up your fuel filter pretty quick.
Yes, I had a 3/4" hydraulic couplers adapted to the drain plugs on the CAT engines, and a hose with a female coupler that went to an air operated pump that pushed it though an engine oil filter and into one of the fuel tanks. The only oil I had to dispose of was that was left in the used engine filter.
After a few oil changes I would cut the pump filter apart and check it for debris. Never found anything whatsoever. After all, it's being filtered continuously in the engine, so it should be clean or you have a big problem.
   / What Do You Do With Your Waste Oil? #135
I put it in 55 gallon barrel than use a pump to put it in 5 gallon containers usually def or 5 gallon buckets when the barrels full, finally it ends up at the recycling center where they take it for free. When I plowed snow for the county we used waste oil liberally on the chains for the salters used a one gallon sprayer that worked pretty good.
   / What Do You Do With Your Waste Oil? #136
Use it to burn my garbage and for dust control in the driveway.๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
   / What Do You Do With Your Waste Oil? #138
The county can spray 1,000's of gallons on the road and dump crushed rock on top "oil & chip"
   / What Do You Do With Your Waste Oil? #139
I don't worry about oil on the ground as we have a
slab of granite 6 ft deep all the way across out property
8 acres. Dirt is 8 ft deep one side and about 3 ft on the other side. When I was in Wisconsin would take the drain pan full of oil get the hose and some basic H pour some basic H in the pan and run the hose and you could run your hand over the grass where I did this and you would not get any oil on your hand.
willy
   / What Do You Do With Your Waste Oil? #140
I'm obviously joking........but I did use a few jugs to treat the posts of my decks, LOL
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
3PT HYD HAY FORK (A52708)
3PT HYD HAY FORK...
INOP/NON-RUNNING 2019 Bomag BMP 8500 Trench Compactor (A57453)
INOP/NON-RUNNING...
