What did you do with your Power Trac today?
   / What did you do with your Power Trac today? #141
I agree; for a 40’ mast. This TV antenna was only about 7’ high. I said, “My word Dad, what were you thinking when you over built this?” It turned out to be a White Elephant as well.
Your Dad and my Dad must have been consulting with each other. I don't know how many time i said to my Dad, 'what were you thinking?' 🙂
   / What did you do with your Power Trac today? #142
On the way to the job.
Laying the tools out.
Using the forks to haul branches to pile.
Getting ready to work on the stump.
Sorry, but i missed picking the stump up with the fork to haul away. My wife wanted a 5 needle pine removed. It had gotten larger than anticipated.
Kool. You have a grease fitting on the upper link at attachment plate, did you install that?
   / What did you do with your Power Trac today? #144
I never thought about that before with the grease fitting bolts. Can the bolts on our front end loader just be swapped out with these grease fitting bolts?
   / What did you do with your Power Trac today? #145
Now, don't i feel stupid. Grease fitting bolt, sigh, mine are home made. The three on the quick attach plate have grease fittings. Right angle on the bottom ones. I figured they were in the dirt more. I don't see why you couldn't swap with "grease fitting bolt".
I see no problem with changing the pin/bolts, or just drilling out the factory one and then cross drill it. But the question is, why? The PT engineering says just the spray lube is sufficient and nobody here has worn them out (that I know of). The spray keeps the tractor much cleaner.
Interesting that with the 1460, PT went to all grease fittings on the loader lube points. I surmise that there was too much load for the spray lube.
   / What did you do with your Power Trac today? #147
One of the things I noticed on the two grease fittings where the cylinder curls the bucket is that when I put the grease in it’s red and when it comes out the ends it’s black. To me it seems like an area where there’s a lot of wear and requires much-needed grease.
   / What did you do with your Power Trac today? #148
This weekend I split wood with our new log splitter
I noticed that too. I use green John Deere and it comes out black. And that pivot Z is not repairable.
With the color change thought, I am going to wonder if I put enough grease in? It makes a big mess as it works out and gets all over the hoses.
I just starting building a table top splitter using what looks like the same splitter only with a different name. It must move pretty quick powered by the PT as the specs are much higher then farm tractors.
   / What did you do with your Power Trac today? #152
I take it it’s not repairable because that round stock is welded tight to the FEL? I don’t know if that means it should be greased more often? That’s the one place on my PT where I get grease all over myself if I’m not careful when hooking up the hoses to the couplers.
   / What did you do with your Power Trac today? #154
You are right. The arms are welded together through the inner cylinder. I think that at least one person here did damage one, though I don't recall that it was a lubrication issue.
Personally, I looked at what would have to be replaced and decided to lube it well and often.
All the best,
Peter
So Peter, since you lube yours well and often, do you or have you ever noticed a color change (if you use colored grease to start with) with the grease as it exits out around the sides of the center Z link?
   / What did you do with your Power Trac today? #156
Yes, I grease the rollover cylinder about every four to eight hours depending on whether or not I am loading/curling it frequently. Our 1445 gets daily use moving hay around (400lbs+/-), which isn't much, but any earth moving, mowing, or tilling is a different story.
I do notice color change. I used a moly enhanced high pressure grease for a long time (black) and couldn't notice anything. The latest high pressure grease that I have is red (Chevron ultra duty grease EP2), and it comes out the edges mixed red and black. Given the play in the two cylinders, I figure some grease goes straight to the outside. The inner and outer cylinders on my tractor have perhaps 2mm of play in them, judging from the outer rim of the outer cylinder as it rotates. When the grease zerks are on loaded, that is thin, side, it is harder to get grease in, but i figure that is when the grease is most needed.
About three years ago, I upgraded my grease gun nipple to a "locknlube" only to discover the locknlube fitting doesn't fit into the loader arm zerks "sockets", :mad::mad::mad: and replaced it with an Azuno 12,000psi grease gun coupler which does fit and is fantastic. (y)(y)I think it is a better version of the locknlube concept and much cheaper. I now almost never have grease escaping out the sides of the grease gun fitting anymore. For me, I used to find greasing the rollover cylinders and the central pin to be a little challenging with keeping the coupler engaged. Not any more. I use an air powered grease gun, which is especially handy for greasing the roller over cylinder job as it seems to take a fair amount of grease. I recycle the squeezed out grease from the rollover cylinder on sliding surfaces, like my post driver, basically any lower tolerance dirty surface that needs some rust protection or incidental wear protection. The grease squeezed out from other fittings I don't usually recycle as there is less of it, and it is generally pretty dirty.
YMMV...
All the best,
Peter
   / What did you do with your Power Trac today? #157
Pulled out 4 wagon loads of firewood today before the trails thawed in the sun. The last two loads were getting questionable as the top surface of the trails thawed. Installing my duals might have let me get another load out. I would have been in trouble early on with the narrow front tires my CUTs have had.
Ken
I was using the 1430 to get a steel safe that a friend bought out of the house cellar. The turf to get to the cellar hatchway door was soft and I have the chevron bar tires. Well the bars sank in to make a perfect pattern of the tire tread but that was about it, even with the weight of the safe. It didn't look the best, but I am just doing a favor and it could have been worse. However, the neighbor came over to supervise with his 4-wheel ride on electric (wheel chair?) and his tires sank down making 3" deep ruts.
Going to have to get me a Azuno couple too.
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2001 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2001 FORD F-350 XL...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
