What did you do for your tractor today?
   / What did you do for your tractor today? #201
That fits real nice. 🍻
Fits even better than it did on the Wheelhorse. Less of a gap by the floorboards. It was actually a bit too wide for the WH so I had to weld shorter brackets. Overall I'm really happy with it for $0.
   / What did you do for your tractor today? #202
Today adjusted the 3 point chain play to the tiller mounted to the newly acquired $3K Rhino 554 and then tilled some. Someday need to pressure wash the roof off from sitting for over a decade outside.
More tilling tomorrow and also digging the two big stumps out with the TLB where the power company removed them to clear the power line. Then engine oil / filter change on the 550 TLB also new tail lights rear work light and factory turn signals for the 554.
If snow is in the forecast, will drop the tilling/ stump removal and mount up the Inverted blower on the original 554.
   / What did you do for your tractor today? #203
Good job on that cab crazy jake - looks like it belongs on that Kioti (y)
Wow - Northern Idaho and you can still run a tiller. I thought the ground would be frozen up there like it is here.
gg
   / What did you do for your tractor today? #204
gg
That Cab does Look Good, Excellent job fitting it up.
The weather has been much wetter and warmer than most years. Snowed last night but I went ahead and started digging out the stump from the power company clearing the line. Stump didn't look that big but really worked the Ford 550 backhoe
Of course since I tilled the field the TLB's R4's are pretty worthless with the snow added.
I did get the stump loose and flipped over but couldn't lift it. Saving the trip out of the hole for another day.
2019 JOHN DEERE 325G SKID STEER (A60429)
2019 JOHN DEERE...
2025 DIGMASTER DM100 EXCAVATOR (A60430)
2025 DIGMASTER...
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
2014 Club Car Carryall 295 4x4 Utility Cart (A59228)
2014 Club Car...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
