What did you do for your tractor today?
/ What did you do for your tractor today? #191
I let my tractor rest until temps warm up in a few days. Also, buying it a new chipper to 'play with' in a few weeks.
That is a great idea!!!👍🏻
I have a portable jump start battery with 2 clamps. It's easy to clamp on and start... Tractor has a usb plug (and phone holder) the usb plug has a voltmeter in it (Amazon) I can see the battery voltage easily and know when it will need a charge or worse, a jump. But it's simple to do now.
/ What did you do for your tractor today? #193
I keep telling myself I'm gonna buy a 'direct to battery' volt meter on the old Kubota. The 6x4 and the JD Buck ATV likewise. But I don't want a digital or LED light bar as they are too slow - I want a small analog where I can see the starter draw load to the battery. Something like a 3/4 x 1.5 rectangular face. Weatherproof of course.
I haven't found one yet that doesn't cost as much as a new shop.
There are MANY cheap little waterproof digital voltmeters that will fit the bill. Just search Amazon and ensure you find a 2 wire waterproof meter in the voltage range needed. I've used these for years on golfcarts. One meter spent 6 yrs outdoors and still worked when I sold the cart. Be aware LED can be hard to read in direct sunlight. Here is what I put on my tractor.
/ What did you do for your tractor today? #195
I put one of those in my drag car years ago, what a great addition. I’m thinking about getting one for the Kioti, now that you mentioned it, thanks scootr.👍🏻
/ What did you do for your tractor today? #196
It dawned on me that the soft cab from my Wheelhorse (which I no longer use to snowblow) would fit my Kioti, so I got to work fabricating some brackets to make the change. The wind really started picking up (50-60+ mph gusts today) but I should be able to finish tomorrow.
/ What did you do for your tractor today? #197
/ What did you do for your tractor today? #198
I checked the price on Amazon, about ten dollars, checked out Napa at least three times that,WTF…..👎🏻
/ What did you do for your tractor today? #199
Finished up yesterday's project - put the old soft cab from the Wheelhorse on the Kioti. Had to weld up some different brackets and cut a few inches off the rear legs. Fits great. The right side is wrinkled from being folded up in storage, hopefully it'll smooth out.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
159116 (A60430)
159116 (A60430)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 TROXELL 130BBL VAC TRAILER (A60736)
2018 TROXELL...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
