Chains What chains to buy for snow?
   / What chains to buy for snow? #1
keony
Gapland, MD
New Holland TC29DA
What kind of chains do you all use?
Any good sources?
Mainly for plowing a hilly gravel driveway, thanks.
   / What chains to buy for snow? #3
Whistlepig nailed it! There ya go, put your order in, no more discussion needed :)
I haven't bought Aqualine Talons yet ONLY because I have to drive down the road very often.
   / What chains to buy for snow? #4
You need to order chains quickly. It 'tis the season.
   / What chains to buy for snow? #5
I have the aquiline MPC tire chains, but I have some asphalt and needed a little less aggressive chain. As said, you need to order now.
   / What chains to buy for snow? #6
Too late on the aquiline MPC's. They are already sold out. but the aquiline Talons are available, and that is probably what you want if you are all gravel.
   / What chains to buy for snow? #7
I use the Aquiline Talons on gravel. They work very well on gravel.
   / What chains to buy for snow? #8
Does anyone use the Talon's on pavement? As in, just transiting down the road or your own driveway (if paved)?
I want something aggressive for the woods, as long as it doesn't kill my driveway (which is far from perfect anyways)
I almost ordered the MPC's last year but wasn't sure how much of an upgrade they'd be over my ladder chains.
   / What chains to buy for snow? #9
I bought my first two sets of ladder H type chains from 301 Moved Permanently. They were priced right and worked. My only complaint was ride quality was horrible due to the pattern of the chain. On my Kubota L4240 I am running a Trygg chain which is similar to Talon. I really like the tires on my gravel driveway for snow clearing. They work great on ice and in the woods all summer in deep mud near ledge.
Everyone is right to order now to have the best selection.
amike
   / What chains to buy for snow? #10
Pick your price. I have Aquiline Talons. Worth every penny. If you are going to buy chains buy them soon. If you wait much longer the suppliers will be sold out until next year.
Tire Chains For ATV, Snow Blower, Tractor, Truck & SUV | Where to get tire chains? - Tire Chains Required
*cringes looking at the link and more so picture*
many states it is illegal to run chains on the regular road. doesn't mater if truck, car, even tractors. some states "extreme northern and into canada" only allow them at certain times of the year. double check ya local laws.
keep the chains loose. allows the chain to spread out in more of a ( vs | shape as the tire rolls over it. creating a much wider area of grip. also it lets mud that will get packed in the grove of tires and chains to fall out. so ya don't end up with a balled tire look (pure mud tire) that is slipping in mud. and it helps keep the chain from being lost within the treads of the tire.
if you wanted paddle wheels, then they would make metal flat bars that would wrap around our tires. but they make chains that are flexible. is there a reason for it beyond allowing a chain to fit multi size tires?
let the tire tread and chain contact the ground, and not holding the tire off the ground via the chain thickness
   / What chains to buy for snow? #11
I may end up doing Talon's on just my fronts, and ladder's on the rear. This way there won't be nearly as much weight on the aggressive chains, as there would be on the filled rears, but in the woods I could still get some good traction when needed, only engaging 4wd when I start slipping. :confused3:
   / What chains to buy for snow? #12
I use Trygg tire chains, very similar to the Aquiline Talons. I believe they are supposed to be run tight on the tire, not loose. Exceptional traction.
   / What chains to buy for snow? #13
Check out Tire Chains by TireChains.com. They're located in west central PA, so shipping wouldn't be too expensive (and chains are heavy!)
With a gravel drive, you can probably go for a more aggressive chain and the folks there can give you advice as far as type of chains, how much clearance is required, etc.
As others wrote, chains can sell out early (especially certain sizes), so don't wait too long.
Thanks everyone, good advice!
   / What chains to buy for snow? #15
When I had my smaller tractor I had "V-bar" chains for all four wheels. Fantastic traction, but exceedingly heavy and not the easiest "implement" in the shed to instal. I only got on asphalt(county road) when I would plow snow on the driveway but they did leave their mark on the asphalt. Had to special order them thru a local tire dealer. They were special heavy duty tractor chains. As I remember, the set of four chains was around $650.
Don't need chains with the new, bigger tractor. I can only imagine how heavy & costly V-bar chains would be for the current tractor.
   / What chains to buy for snow? #16
I second (or third?) the Tirechains.com site. I was able to get a set of rear chains for my B8200's turf tires IN THE WINTER when I got desperate for traction on icy snow. Euro style, is what I remember, and they worked great. The guy I spoke with on the phone was very helpful, and seemed to know his product. Reasonable price, but shipping will bite, since they weigh a lot! In fact, I opened the box and took the two chains one by one down to the barn- couldn't use a cart, because of the deep snow and narrow path I had shoveled. Ah, winter.
   / What chains to buy for snow? #17
Yep...you don't want to wait until winter to buy 'em...and you don't want to wait until it snows to install them.
   / What chains to buy for snow? #18
[snip]
For a bigger tractor like yours, I can tell you: They're heavy! A neighbor bought an a Kubota M6040 with R4s after Snowmageddon, and found he needed chains for good traction in snow. While it can be done alone, it pretty much takes two people to put them on. They go on in November and stay on until April, snow or no snow!
   / What chains to buy for snow? #19
Ha, ha - of course, the first time I decided I needed chains, the snow was knee deep and risin'. The "first instal" was VERY unceremonious, time consuming and educational. Thereafter, they went on in warm wx. The chains I got had 2X the number of cross links as normal chains and "V's" were really big. On a frozen driveway the little tractor actually "sat up" on the V's and I really don't think much of the rubber tire touched the ground. To say the tractor rode like a cob would have been a major understatement.
Plowing snow at slow speeds was the order of the day - otherwise, with the seat belt off there was always the fear of being bucked out of the seat or with it on, the belt almost cut me in half. I had the little tractor(Ford 1710 4x4) for 25 years and only used the chains for four winters. I developed some very imaginative ways to plow snow on my mile long driveway - without chains.
   / What chains to buy for snow? #20
Tire chains .com, way cheeper than anywhere else I could find and the v bar chains I put on the rear of my little massey are great. I plowed up hill through 10 or 12 in of snow and then found out I had forgotten to put it in 4x4. Get the ones with the extra cross chains for the smoother ride and more traction. You will love them.
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
2008 KOBELCO SK210LC EXCAVATOR (A60429)
2008 KOBELCO...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
