Well water acidity
/ Well water acidity #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I tested the pH in my well water, for pool use. It was off the scale in acidity. (That explains wjy it fizzes up like crazy when I add baking soda, to clean battery terminals...)
Is there a problem with water like that for household use? Is there an easy way to correct it? I know the water people will have a machine and a payment to fix it...
/ Well water acidity #2
Generalizing and relying on old memory but potable water should be between 7.0 and 8.6 PH. Will not quarantee the accuracy.
Egon
/ Well water acidity #3
I think it can eat holes in copper plumbing. I vaguely recall testing our water's PH because I'd come across that while researching wells on the web. Ours was fine, so I didn't dig into it further.
SnowRidge
/ Well water acidity #4
Here's my well story. I bought the land with well already there. Tried to get well logs but was unsuccessful. Hooked up electrical and ran well then took sample to lab. Water was fine. It tasted great. But lab does not test for acidity. When house was built I noticed blue stains appearing in tubs. So I tested and found ph around 5.8-6. This was below what Sears recommended on their neutralizer. I bought one anyway and it helped but was a pain to keep up with. To make a long story short, I finally got logs and found I had a "livestock" well drilled to 100 feet and cased to 50. This was after 1000's of dollars spent in piping to house and treating water. I had a new well dug to 300 feet. Expensive, but not as bad as replacing the copper plumbing in my house if it wore out, or sprang a leak. I learned my lesson about buying property with an existing water well.
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2020 TRI-W T/A STEPDECK TO MOUNT SEPARATOR (A60736)
2020 TRI-W T/A...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
