welding bucket hooks
/ welding bucket hooks #1
pemad
Syracuse, New York
B7510 HST
Wondering if there would be any issue with welding bucket hooks with the loader hooked to the tractor? I figured I would just disconnect the batter terminala and start welding. Anyone have any thoughts on this?
I will be using an arc welder.
Thanks!
/ welding bucket hooks #2
You probably would not have a problem if your electrode were close to the welding. However...When I welded mine on I felt the way you did and just took the bucket off, then welded on it.
/ welding bucket hooks #3
You can do it either way and shouldn't have any problems.
I've always welded right on the tractor as long as the ground is pretty close to where you are welding. Take the battery cable off if that makes you feel better, which I've forgotten to do many times with no problems there either.
/ welding bucket hooks #4
I had my Bobcat dealer weld on rear stabilizer plates for my S300 skidsteer. Before, I had tried not to weld anything directly to my CUT or SS or at least disconnected the battery. The guy doing the welding says he never disconnects the battery and has be doing welding for years.
/ welding bucket hooks #5
Thanks!
Just ground it close ( and well) near the point of weld
/ welding bucket hooks #6
I just did this. I did not disconnect anything, and had no issue.
/ welding bucket hooks #8
HELLO TO ALL,
WARNING!!
be sure to cover the hydraulic cylinders, to avoid any
weld spatter!
good luck with your project.
accordionman
wlbrown
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
32ft Flatbed Equipment Trailer (A64553)
32ft Flatbed...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
CAT 735/740 Final Drive (A68134)
CAT 735/740 Final...
PORTA POTTY (A67714)
