Welding brackets on tractor frame
/ Welding brackets on tractor frame #61
Typically, holes drilled into the center 1/3 of a 'beam' will minimize loss of strength if all forces on it are linear. They are not in a frame or ROPS. I wouldn't drill or weld on either.
Brackets may be attached under existing bolts, say that hold on a loader tower etc. Two-pc brackets can be designed that wrap/clamp around something, frame or ROPS, loader arms, etc.
Well said.
Ever have a close look at aircraft wing spars? They are full of holes like you point out, never near the edges or in web and always centered.
A good clean de burred hole in a web center is perfectly safe.
On vehicle frames you'll find tons of holes generally for options.
Frame welding is a big no no but bolting is accepted, in fact some truck frames are extended by bolting methods.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A59230)
2021 Ford F-250...
68" AERATOR (A60430)
John Deere 3025E (A53317)
John Deere 3025E...
