Welding ARGGGGGG!!!!
/ Welding ARGGGGGG!!!! #21
Thats an easy solution, Make your coupons like the real world welding you're trying to do. /forums/images/graemlins/grin.gif
/ Welding ARGGGGGG!!!! #22
Bob, Just about a year ago I needed to make a piece of equipment (no farm sales, used equipment yards, or even proper scrapyards here) so persuaded someone I knew to do the welding for me. I had not used one myself for 26 years. One of his welds failed, I bought myself a welder, fixed the broken weld at the 4th, maybe 5th attempt, and then began to make more equipment. Just keep at it and you will get better. I am not a good welder, my eyesight is not the best, and my hand is not the steady implement it needs to be (probably a brain surgeon would make a good welder?) I try not to let anyone see my efforts, but as long as they hold I am happy. Unfortunately I have no choice of grades of rods. They come in different diameters, and that is all the choice I have. What I do know is that I believe people who post here - they sound knowledgeable, the photographs of projects always look good, and the few tricks I have picked up from their advice have been successful. If I ever have a serious problem I will ask here first. Old McDonald.
/ Welding ARGGGGGG!!!! #23
Hey Mac...how ya been?!
Brain surgeons don't make good welders.....hand em a stinger and they will try to hit golf balls with it... /forums/images/graemlins/crazy.gif
Think I am finally getting the hang if this welding stuff.. Biggest roadblock has been spending 40+ years soldering delicate electronics components and being way too woosie when I was welding. Still not perfect but I am much more secure in getting after it and with a little more practice think I will be making welds I won't be ashamed to take pictures of.
Thanks guys, you really did help...
/ Welding ARGGGGGG!!!! #25
My experiences stick welding have given me a few tricks I remember:
-If you're tired and hands are a bit shaky find something to brace or lean against. A wavery rod gets a lot of slag inclusion.
-The tendancy on thin material is to pull back or let the rod burn back too far. This generates too much heat and starts undercutting badly. If you are in a thin area or an outside corner etc you need to keep a good consistant feed and short arc, usually for the rods I use that means the rod flux is touching the base metal.
-Keep the rod tip in the puddle. This gets friggy for overhead and vertical down welding. Vertical down stuff I ask the welder shop for a fast freeze flux.
-I don't know my rod types well and rely on the welding shop a lot for picking my rod. I think I have a box of 7014 or 7018 that is used most of the time and I buy the rest as I need it.
- DC is nice, really nice.
For us part time welders it can be a pain getting our bead right after not welding in a few weeks or months.
/ Welding ARGGGGGG!!!! #26
"For us part time welders it can be a pain getting our bead right after not welding in a few weeks or months."
That statement hits it on the nose. If I've done a bunch of welding for awhile all is good. Stop for a month and my hands get shaky at first. Then I have to fire up the angle grinder /forums/images/graemlins/grin.gif
/ Welding ARGGGGGG!!!! #27
I found out that when I gave up the booze...my hands were a lot steadier and I really could weld.For years,I thought I'd never get the hang of it....the real problem was just the DTs (really the booze...but denial comes naturally to people like me) /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
/ Welding ARGGGGGG!!!! #28
Tudo bem as they say here. Have not made that subsoiler yet, but have bought the steel and will do it this winter I suppose. In the meantime I have made a few other things and am having the irrigation installed for 300 new olive trees - on the land I need to subsoil. I might be getting my son's old digital camera for Xmas (I bought it in the first place!!!) so will post pics if all goes well. Old McDonald.
/ Welding ARGGGGGG!!!! #29
A trick I use to keep my hand steady is to wrap the handle cord around my arm one time. It helps. Also, don't try to weld steel with cast iron rod. /forums/images/graemlins/tongue.gif I did that recently and couldn't figure out why it wanted to stick so bad. I felt pretty stupid when I figured it out. Seems the CI rod was the same color as the 7014 I normally use. I just grabbed the wrong rod by mistake. /forums/images/graemlins/crazy.gif I won't do that again.
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
MSC Horizontal Band Saw Machine (A59317)
MSC Horizontal...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
