Welding advice
/ Welding advice #1
Travelover
Elite Member
Washington
B7100
Let me start by saying I'm a rookie welder, with a Lincoln 225 AC tombstone
I need to weld together two pieces at right angles (heavy walled pipe onto a plate), both are mild steel 1/2" thick. After it is welded, I need to machine the weld high spots on the pipe flat on a lathe.
What rod type, diameter and amperage would you recommend?
Thanks.
/ Welding advice #2
I have the same welder, and I recently welded some 1/4 inch wall pipe to 1/4 inch plate. I used 3/32 6011 at 75 amps for a root and 1/8 7018 ac for the cover. I know 1/8 6011 would have been better for the root, I just dont have any. I am sure the same would work just fine for you work, just do another one or two passes.
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
21ft. T/A Homemade Parade Float Trailer (A66736)
21ft. T/A Homemade...
