Welding advice
/ Welding advice #1
Travelover
Elite Member
Washington
B7100
Let me start by saying I'm a rookie welder, with a Lincoln 225 AC tombstone
I need to weld together two pieces at right angles (heavy walled pipe onto a plate), both are mild steel 1/2" thick. After it is welded, I need to machine the weld high spots on the pipe flat on a lathe.
What rod type, diameter and amperage would you recommend?
Thanks.
/ Welding advice #2
I have the same welder, and I recently welded some 1/4 inch wall pipe to 1/4 inch plate. I used 3/32 6011 at 75 amps for a root and 1/8 7018 ac for the cover. I know 1/8 6011 would have been better for the root, I just dont have any. I am sure the same would work just fine for you work, just do another one or two passes.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2014 Ford F-250 Knapheide Service Truck (A66736)
2014 Ford F-250...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
