Welder (value) question.....
   / Welder (value) question..... #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Is a Lincoln "Power MIG" 210 that is "[FONT=&quot]brand new box was opened just for pictures never used this is a welder for a begginer or a pro it does it all very nice machine comes with gauges , lead , . 110 adapter & 230 adapter and more please see pics"
and of course, there is only ONE picture of the side...
He is asking $700
Thoughts on this for someone who's never used much less owned any type of welder??[/FONT]
   / Welder (value) question..... #2
Is a Lincoln "Power MIG" 210 that is "[FONT="]brand new box was opened just for pictures never used this is a welder for a begginer or a pro it does it all very nice machine comes with gauges , lead , . 110 adapter & 230 adapter and more please see pics"
He is asking $700
$700 is a VERY good deal!
BUY IT !!!!
   / Welder (value) question..... #3
it is a very good price, keep in mind the higher amperage's will require the 230V. and it's "MIG: Weld up to 5/16 in. mild or stainless steel or aluminum* up to 3/16 in." specs are good for most usage, you can't weld very thick steel or aluminum though..
   / Welder (value) question..... #4
Yup ......absolutely correct!
Not suitable for skyscraper or bridge beam welding.
I think OP stated he has never welded before.
Big steel is likely not on his horizon.
Well, the closest I've ever gotten to welding anything ever in my life..... is using a dollop of JB Weld...
Cripes... I'm leaving town on Friday too.
I've obviously got 110 covered but have something like a 50' roll of leftover 8-3 WG that I used to carry current over to a secondary panel in the garage. I've often wondered about using it to run a 220V to near the garage so I could use something like this or maybe plug in a generator (with requisite ...I forget what they're called, isolation panel)
Thanks for the comments!!!
Couple scenario's...
1. I have an industrial backhoe. Need to take steering cylinder off. The pin that holds cylinder on has a bolt that locks pin into place. The lock bolt has been sheared and can't be grabbed. I was thinking (and going to take to machinest friend) to have washer welded to bolt.... nut welded to washer so now we can try some leverage.
2. I have a 15' flexwing mower. It has the hand cranked stand that goes on the front of it so you can hold front up while putting it on/off. The mower never had a stand since my buying it. I had one welded on a year ago.... and over winter it snapped off (looks like they only tacked it on 4 corners). I want to weld another one of those on so I can remove and leave it standing.
Those are my immediate issues.... yeah, I could have them done for well under $700 but with the backhoe, tractor (we have three tractors here) several mowers, box blades, backhoe.... PLUS the "toy" factor..... I'm thinking over time, I might get to use it.
   / Welder (value) question..... #7
THIS IS THE TIME!
and ..... THAT IS A GOOD DEAL!
GET IT...before someone else does!
I have a Kubota L48 TLB, and two other tractors, plus other stuff too.
I am old, and rapidly becoming decrepit.
I have been retired for 20 years, and really don't NEED a welder either.
I bought the Hobart Handler 190 MIG (220V only) 2 years ago.
I like toys, and this is a sweet Mr. Fixit toy!
   / Welder (value) question..... #8
Generator transfer switch!
   / Welder (value) question..... #9
Worst case- Buy it, re-sell and put $400 in your pocket. That will pay to have your stuff fixed.
   / Welder (value) question..... #10
He is asking $700
As someone who owns that model PowerMIG (original owner, bought new), I'd say yeah: ... for that price, if it's in the condition described, it would seem to be a good deal and would be a fine welder to learn on (I did)
FWIW, I've welded 1" plate with mine ... and also done ALU with the spool gun I have for it.
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
1997 MONON 102" X 53' T/A VAN TRAILER (A51243)
1997 MONON 102" X...
