Welded some hooks on my FEL
   / Welded some hooks on my FEL #81
Looks like this will end up a lot longer than the "Poor FiFi Needs Tractor Advice" thread from a while back...............chim
   / Welded some hooks on my FEL #82
One day I was motoring down the road in the big truck; the road was icier than icy, and all at once there was a jack-knifed rig about a mile up ahead. So's I shut down on the shoulder to take a peeky see-- not enough room to get by him so all I can do is wait, OK! As the time went by there got to be more and more big trucks stopped on the shoulder waiting for the wrecker to come and pull the jack-knife out. The line of trucks was only about three miles long when a "supertrucker" decided he didn't have time to wait and passed the line of trucks that were just setting along the Interstate for the fun of it !! Well, when he went around the wreck HE slid off the road behind the wreck, obstructing the means of clearing the road by the first wreck. He had to be pulled out by the wrecker before the wreck could be pulled out!!!! Moral of the story---WHY????????? Is the obvious so hard to see??? MERRY CHRISTMAS AND A HAPPY NEW YEAR!!!!!!!! Don
   / Welded some hooks on my FEL #83
So, how much cheaper were these than a real hook? Or were they easier to weld? I'd snatch that hook straight the first time I used it!
   / Welded some hooks on my FEL #85
I'm reading this and thinking what am I missing here. Good ideas, great initiative, yet they didn't weld a "hook" on where a "hook" should go. As a mechanical type, possibly a tunnel visioned one at that, I quickly jump to the bending moment part of the equation and conclude that the severe reduction in strength from the bootleg hook doesn't justify the few dollars that may have been saved. Then I think, maybe they are more worried about the hook being ripped off the bucket than straightening the hook out! This is supported by the "beginning to weld" and the "no torquing of the hook" statements. I looked again at the two substitute hooks and noticed that they had a larger, easy to weld "footprint". I can now see where a proper hook may seem a little trickier to weld on. It sits on its edge and if not "burned in deep" could break over sideways and rip off. I'm thinking that most if not all of us here on the board immediately saw that these hooks weren't coming off, due to good welding, and focused instead on the hooks possibly straightening out under load.
Just a thought.
Greg
Greg
   / Welded some hooks on my FEL #86
<font color=blue>I'm thinking that most if not all of us here on the board immediately saw that these hooks weren't coming off, due to good welding, and focused instead on the hooks possibly straightening out under load. </font color=blue>
That's what I saw. The welding looked fine, it was the 'hooks' I was concerned about.
   / Welded some hooks on my FEL #87
I'm still waiting for the pictures of the "straightened hooks". Bet I wait a long time when tractors only pick up less than a ton.
   / Welded some hooks on my FEL #88
<font color=blue>Bet I wait a long time when tractors only pick up less than a ton. </font color=blue>
Perhaps, but what if a newbie to TBN came along with something bigger than a compact tractor and thought these hooks were OK because no one pointed out they were being used in a manner they were not designed for?
Using New Holland as an example, their CUT loaders can lift from 750 lbs to 1,955 lbs. There are several people on this board with TN series tractors, lift capacity of 3,275 to 3,523 lbs, as well as JD 110s, Case 580, etc.
There are at least four ways to solve problems. There are 'Right' solutions, 'Wrong' solutions and 'It's wrong, but it will probably work' solutions. If people are not informed of which are the 'Right' and 'Wrong' solutions, they might end up with the fourth solution...'It's wrong, and it didn't work."
   / Welded some hooks on my FEL #89
What might go unoticed here is that the lift capacity of the FELis greatly surpassed in force when curling the bucket after youmaxed out the FEL ...RayBee
   / Welded some hooks on my FEL #90
<font color=blue>What might go unoticed here is that the lift capacity of the FELis greatly surpassed in force when curling the bucket after you maxed out the FEL {lifting capacity}</font color=blue>
Great point! /w3tcompact/icons/clever.gif
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Vermeer 605 XL Round Baler (A59814)
Vermeer 605 XL...
5' MOWER (A52706)
5' MOWER (A52706)
KBH 25T Tender (A56438)
KBH 25T Tender...
