weld on back hoe teeth
/ weld on back hoe teeth #1
spo307
Levittown & Long Eddy NY
kubota L4400
i am building a 12" back hoe bucket and am looking for weld on shank, pin on teeth, were can i find them, not kubota I have heard there a lot of money
/ weld on back hoe teeth #3
I was just looking for shanks and didn't see any. Looks like a good place for teeth though.
/ weld on back hoe teeth #4
When I was building my 9" bucket a while back I could find them on Ebay. The consensus was to use bolt on though so you could remove them if you wanted to get a smooth bottom trench.
/ weld on back hoe teeth #5
I bought some teeth a couple of months ago. They were Hensley 00SPS (zero zero SPS) teeth with # 2898W00 adapters (weld on shanks). I got them from Romac Industrial Parts, Inc. They were about $12 each, including shipping, for the shank and tooth assembled but they sell them separately. The assemblies come with the teeth crimped on. They were very easy to deal with over the phone. 877-727-6622
They are a nice size for a small bucket. There are 5 of them on the 18" bucket on my Takeuchi TB 108 excavator and I'm putting three on the 10" bucket I'm building.
/ weld on back hoe teeth #6
Sorry. I missed the "pin on" part in your post. I'd still call Romac or check there website. They may have something you can use.
/ weld on back hoe teeth #7
Check other dealers parts departments. I've found good prices at the local Deere dealer. It doesn't matter where they come from, so call around.
Inquiring about prices is cheap; call everybody in town! I once made ~25 phone calls to find a replacement door for a truck....it makes a big difference and it gets easier with each call....but some guys might get a bit tired of you.... :)
I am looking for weld on shank, pin on teeth that pin to shank in case they break.
/ weld on back hoe teeth #11
Maybe toothbar companies.
W.R. Long or Markam
/ weld on back hoe teeth #12
I used some round 20mm spring steel cut to length 15 cms about and welded them directly to the bucket bottom, they work very well, the welds do break from time to time, and so need welding back on, but being very small, they do not put much resistance to the bucket when digging.
jemjack
Called romac, weld on shank, rock tooth and pin $ 20 ea. I need 3, don't know shipping yet, he is out of the shanks wont be in till the 16th nice guy, I told him I custom made the buck based on a kubota bh 90, and he talked me through it
placed the order yesterday with ROMAC very helpful on the phone, he was shipping same day.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
RHINO SE10 BATWING/DITCH BANK MOWER (A63276)
RHINO SE10...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
UNUSED JCT HYD AUGER DRIVE AND BITS (A65055)
UNUSED JCT HYD...
2154 (A65055)
2154 (A65055)
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A67148)
2007 VOLVO VHD...
