Weighting back-blade
/ Weighting back-blade #1
couchsachraga
Adirondacks, NY, USA
John Deere 4520 cab... formerly Yanmar 336D
Greetings...
Backblade is near YM336D...I'll be playing..er...WORKING with it this evening /w3tcompact/icons/smile.gif. I plan on trying to re-grade (crown) a road as well as deepening some trenches...should I weight the blade (cement blocks, etc...), or will it's 300+lbs be enough to move earth? (I'm used to using a land plow with some down pressure...).
Thank you!
Couchsachraga
/ Weighting back-blade #2
I'd try it bare first. The limitation will probably be the amount of traction the tractor has. At least that's been my experience. If you've got too much of a load you'll spin the tires.
/ Weighting back-blade #3
When I box blade I hang my suitcase weights on the edges to add an extra 240lbs to the existing 500lbs. It helps a great deal.
/ Weighting back-blade #4
Weights make a difference, but it depends on what your soil is like. My drive was a little too dry and hard packed - the weights helped, but I think a little more moisture in the soil would help tremendously!
Worked Great without Weight!
Greetings...
Well, I started replacing the ditches over the weekend. I was VERY impressed-a little tilt, a little angle and WOW look at that dirt (and rocks!) Move! I did manage to break a piece off where the pin keeps the blade from swiveling (BIG rock, and no doubt going a little too fast-I slowed down a gear after that /w3tcompact/icons/blush.gif).
Cheer,
Couchsachraga
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
Caterpillar 920/930 Wheel Loader parts and service manuals (A63117)
Caterpillar...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2017 Nissan Pathfinder SUV (A61574)
2017 Nissan...
