Watering grass on distant area - pump?
/ Watering grass on distant area - pump? #1
MNBobcat
Platinum Member
I would like to be able to use a sprinkler that would cover a very large area to water new grass seed in a field. I'm going to need to run garden hose about 200 feet.
Has anyone done that using 3/4" garden hose from the water source, to an inline pump and then to the sprinkler?
I'm wondering if using a pump at the end of the run to increase pressure will allow a larger area to be watered using a rotating irrigation sprinkler?
I assume the pump helps with the water pressure but I don't know if it would fail to produce the desired results because of the water volume?
/ Watering grass on distant area - pump? #2
Booster pump sounds like a great idea.
/ Watering grass on distant area - pump? #3
What is the water flow at the source like? Are you just connecting to an outside faucet on a house? I would use 1 1/4" Polyethylene Potable Water Pipe to get to your sprinkler head ($100' is only $39 at Menards).
/ Watering grass on distant area - pump? #4
Yeah at least 1" poly. You can't draw from a garden house as it will collapse. Booster pumps need to be at the start of the hose/pipe, not the end. They make big gun sprinklers that cover a long way, but you will need like 30 GPM at 90 PSI to make one of those work.
2017 BOBCAT E50 EXCAVATOR (A65056)
2017 BOBCAT E50...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2018 Chevrolet Suburban 4x4 SUV (A66738)
2018 Chevrolet...
