Water separator for small air compressor.
   / Water separator for small air compressor. #21
I have a stationary compressor with a "radiator" of copper pipe before it runs to the point of use. Just cooling the air does a lot to stop the water at the point of use. Also, that Motor Guard filter works wonders. I have one set up as a portable unit (quick connect fittings) that I use when sandblasting and need really dry air.
What Motor Guard filter do you have 3T? They seem to make a slew of them as well as inline disposable filters.
Thanks to all who gave me a clue on this. It seems that it is best handled on several levels. 1. Tank drainer. 2. 25' of Ancillary air hose to first separator device. 3. Down stream separator . 4. Regular airline to tools, etc. from separator 5. Motor Guard disposable air line filter at or near terminal point.
Perhaps then it'll stop spitting.
   / Water separator for small air compressor. #24
I have the M60. However, I believe there is also an M40 and M30 that the only difference is the inlet & outlet port sizes. The M60 is 1/2" so I had to get bushings to fit my 1/4" quick connects.
Just an update so others know what cured my problem. The tank is kept dry with an inexpensive automatic drainer as suggested by Rsy. I curled 25' of air hose as suggested by bigtiller. I purchased a cheap (17 bucks) water separator that put at the end of the 25' curled air hose and I got one of these (m26) Motor Guard filters as suggested by 3T's. This last filter (Motor Guard) was probably not needed and maybe a waste of 90 bucks as when I disconnect it and run the compressor with just the water separator, no more spitting occurs. Bone dry. I am happy to have dry air for a change thanks to all who gave me a clue.
Kubota L2800 (A47384)
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2002 John Deere 5220 (A50120)
2002 John Deere...
