water pump
/ water pump #1
easley man
easley sc
lb1914
Hi i have a Kioti 1914 and it is leaking from
the fan what could it be?
/ water pump #7
I assume you have antifreeze flying. Probably the pump shaft seal. Usually when they go bad, the shaft bearing is starting to go. There is a chance that the gasket from the pump to the block is leaking but the fan will just blow the antifreeze back on the block and not pick it up and sling it around. Some pumps can be rebuilt and others you just replace the entire pump.
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
2022 EZ-GO ELITE...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-844...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A64556)
2018 Nissan Titan...
2017 Ford E-450 Super Duty Shuttle Bus (A64556)
2017 Ford E-450...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
