water pump
/ water pump #1
easley man
easley sc
lb1914
Hi i have a Kioti 1914 and it is leaking from
the fan what could it be?
/ water pump #7
I assume you have antifreeze flying. Probably the pump shaft seal. Usually when they go bad, the shaft bearing is starting to go. There is a chance that the gasket from the pump to the block is leaking but the fan will just blow the antifreeze back on the block and not pick it up and sling it around. Some pumps can be rebuilt and others you just replace the entire pump.
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
2001 International 3800 School Bus (A64194)
2001 International...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2022 EZ-GO ELITE...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A67148)
2019 ISUZU NPR 4X2...
