Want a 3PH sprayer...
   / Want a 3PH sprayer... #11
The larger the boom, the fewer passes you have to make. But, if a "large" sprayer is not a convenient choice, there's no reason a smaller unit won't work well. A 55gal. tank would just have to be filled twice.
Glyphos is a generic Round-up. The concentrate I get comes in 2 1/2gal containers and is applied at 2 qts/acre. I don't think it matters how much water you mix it in, as long as you lay down about 2 qts./acre.
I am no pro at this, but I generally mix the chemical in plenty of water, then make at least two overlaping and/or crisscross patterns to help avoid misses. A little more time consuming, but it corrects for my poor driving.
OKieG
   / Want a 3PH sprayer... #12
OKieG
   / Want a 3PH sprayer... #13
Fimco 60 gal (55?) for me - 3-section, fold-up booms. Love it.
I thought I wanted boomless - can spray through fences / around trees. After some thought and use, prefer the boom model - for reasons others have listed.
Keep the booms lubed (WD-40) and you can go through gates or between trees (slowly) and have 'em pop back out.
Get out the utility knife, clamps, valves -- hook up a wand for spot spray.
DEFINITELY, clean out the pump before storage. I hooked up a "quick-detach" gizmo so I don't have to wrestle with the hoses and barbs. Now, it's a breeze to "flush with oil" before storage (i.e., between each use).
Be sure to get the book(s) - mine has excellent directions on how to determine application rates.
Happy defoliating!
mlg
   / Want a 3PH sprayer... #14
Happy defoliating!
mlg
Thanks for info guys.
Looks as if I will go with a Demco model. There are two dealers within 50 miles of me.
What type of price should I be expecting on a 55 or 85 gallon unit?
   / Want a 3PH sprayer... #17
I recently ordered a Hardi 55 gallon 3 point sprayer with a 14 ft boom and diaphram pump. To give you some idea of price, I paid 1590.00 with a hand sprayer and 25 ft of hose.
I expect to have it later this week if you have any specific questions.
   / Want a 3PH sprayer... #18
Holy Bejesus!
I thought it would be about $500-$600.
I am looking at getting a 2 or 3 bottom plow and a 2 row planter as well.
My hobbies are getting more expensive everyday!!!
Holy Bejesus!
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2020 Toro Workman HD Gasoline Utility Cart (A50322)
2020 Toro Workman...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
