Want a 3PH sprayer...
/ Want a 3PH sprayer... #21
What "oil" do you use in the pump and what "books" are you refering too?
Gary
/ Want a 3PH sprayer... #22
Gary
/ Want a 3PH sprayer... #23
If this application is going to be a one time job, you should be able to find a lawn care co. that will do the application for you, for less than the cost of the new sprayer?
/ Want a 3PH sprayer... #24
/ Want a 3PH sprayer... #25
LeadPoison,
If you have a soil conservation office in your area, they will rent you a sprayer for next to nothing a day.
/ Want a 3PH sprayer... #26
LeadPoison,
/ Want a 3PH sprayer... #27
Ditto on all that farmwithjunk said. Follow his post exactly. Tee-jet is the tip to get. I like the XL in a size 02 - yellow. A small boom with XL tips will give much much better results than a boomless nozzle.
A 55 gallon sprayer would be good for an M4900. You will have to fill it once in the middle of your job.
Get two 3/4" NPTM 90 x 3/4 F banjo and two hose to 3/4 M banjo fittings for your pump connections. This will let you unhode your pump in seconds. Otherwise, removing the pump to clean and oil it (30w motor oil is fine) is much more difficult. Clip or tie wrap the banjo fitting levers so the don't open and dump your sprayer contents. This last advice comes from experience.
/ Want a 3PH sprayer... #28
Nope and never heard of them.
/ Want a 3PH sprayer... #33
<font color="blue"> hooked up a "quick-detach" gizmo so I don't have to wrestle with the hoses and barbs. Now, it's a breeze to "flush with oil" before storage (i.e., between each use).
</font>
Would you explain this quich detach gizmo a little more. A picture would be even better. Sounds like something I would like to do but don't think I understand the concept.
/ Want a 3PH sprayer... #34
</font>
/ Want a 3PH sprayer... #35
<font color="blue"> Get two 3/4" NPTM 90 x 3/4 F banjo and two hose to 3/4 M banjo fittings for your pump connections. This will let you unhode your pump in seconds. Otherwise, removing the pump to clean and oil it (30w motor oil is fine) is much more difficult. Clip or tie wrap the banjo fitting levers so the don't open and dump your sprayer contents. This last advice comes from experience.
</font>
How about a picture of this setup. Unhooking the hoses from a barbed fitting (especially a metal one) can be a royal pain in the behind. I am looking for a better solution. I said way too many cuss words last Saturday.
/ Want a 3PH sprayer... #36
</font>
/ Want a 3PH sprayer... #37
the farmers cooperative sells sprayers in my area. i like the cluster nozzle sprayers for my food plot applications my 55 gallon sprayer covers 35ft without any booms to hang also don't have to clean multiple spray tips.stevenstractor.com has several different sprayers for sale on their web site
/ Want a 3PH sprayer... #38
/ Want a 3PH sprayer... #39
FYI I just bought this P-K Sprayer at Rual King
http://www.pkmfg.net/S3P55PE3%20UTILITY%203-POINT%20SPRAYER.htm
It came with a Spray Gun also, no pump!
I got a 6-Roller pump with quick coupler to go with it ..extra.
I guess the reason for no pump with it is because it's easy
to go elec or PTO.
I have a little less than $500 in the complete set-up!
I have not used it yet, just picked it up last nite.
I think it will serve me and the 5 acres that I cut well?
Anyway, I'm out the door to go find out /forums/images/graemlins/tongue.gif
Gene
/ Want a 3PH sprayer... #40
to go elec or PTO.
Gene
3pt Peanut Wagon QA Hitch (A64127)
3pt Peanut Wagon...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
John Deere D110 Riding Mower (A62679)
John Deere D110...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
KUBOTA RTV900 ULTILITY CART (A64276)
KUBOTA RTV900...
