Wallenstein vs WoodMaxx Chippers
/ Wallenstein vs WoodMaxx Chippers #21
My first chipper was a Wallenstein BX42s. I used it with my Ford 1700 - it was great. Then I got my 2009 Kubota M6040 and traded up to the Wally BX62s. Its been a fantastic chipper also. The ONLY thing I have to chip are pine trees - 6" in diameter and smaller. I thin my pine stands every spring and identify, cut, drag and chip between 750 to 900 small pines every spring.
Its all I can do - to drag 6" pines out of the thickets to a pile then later to chip. That's why I don't have the 72 or 92 and I'm NOT ABOUT to increase my work load by cutting larger trees into chunks. Handling 750 pines in the spring is quite enough - thank you.
BTW - I've never needed hydraulic in-feed on either chipper. Everything goes in butt first with no limbs removed. The chipper will grab the trunk and pull the pine in like a child grabbing a candy cane. It actually such a strong and fierce inward pulling action - many who have come to assist have been noticeably frightened.
/ Wallenstein vs WoodMaxx Chippers #22
Ditto with oosik,
No one mentioned about sizing the chipper to what you plan to chip. My WM-8M (not hydraulic) is perfect for my pine/fir with all straight thin trunks. If you’ve got crazy branches to chip, get a chipper that can handle ‘em.
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59910)
2020 VOLVO VNL760...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
Zero Turn Mower (A59231)
Zero Turn Mower...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
