Wall Timer Light Not Working
/ Wall Timer Light Not Working #1
MoKelly
Super Member
Jefferson County, Mo, ... about 35 miles out of St
Bobcat CT235, Bad Boy z-turn, Suzuki Vinson 500 and F-150
I’m praying for some simple answer.
I have a wall light timer switch to control 2 sets of outside porch lights. Isn’t working. It’s an Intermatic.
It’s:
- single pole.
- in manual mode
- new battery
- unit only 6 months old. Worked for sure a week ago
- outside bulbs still work in different fixture
- circuit breaker on
- porch light on same circuit works with on/off switch
- All GFI’s are working - none tripped.
Anything I’m missing here? I even tried a new switch I had. The new switch does not work either.
Thanks.
MoKelly
/ Wall Timer Light Not Working #2
New switch? So the switch probably works, but you have no light?
It worked as is, then just stopped working?
A simple check for power at the timer?
I'm kinda still thinking GFI. Did you trip and reset it. Do you even know for sure which one runs this light?
Yes - new switch.
I have power at the timer. No doubt there as I got a slight shock. But - no power at the outdoor light - since s known good bulb does not work.
I guess I need to take the light fixture down to see if it’s hooked up ok or something messed up there.
MoKelly
/ Wall Timer Light Not Working #4
Amazing how something so simple can occupy so much time! Yep, another ten minute project.
/ Wall Timer Light Not Working #5
you need to test both hot and neutral legs going out to lights and switches. if a neutral gets knocked out under a wirenut, nothing will work.
Well - I now must admit I am a fool.
I went out to take the outside fixture off. I climb up the ladder - this time to the top of the light to get to the screws.
I notice a photocell. Never saw that before and where did it come from? I googled the fixture. Well - the fixture comes with the photocell plugged. If the consumer wants to use the photocell they remove the plug.
Somehow, the photocell plug came out. So, the light didn’t react to the timer switch during the day. I guess had I tried it at night it would have worked.
I feel pretty useless right now. Never thought of that aspect.
I plugged the photocell and all is good.
Sorry folks.
MoKelly
/ Wall Timer Light Not Working #7
Why? Just be happy it didn't take another four hours of your life.
/ Wall Timer Light Not Working #8
ha... been there done that. those pesky 1/2" round hidden photocells.
You should exactly like my wife. She said the same thing.
I am glad it’s fixed and I am finished. But - I like to think of myself as smarter.
MoKelly
/ Wall Timer Light Not Working #10
It's all the ten minute jobs that aren't, that are the bain of my existence. Not the big projects. I don't even start them. lol
Sad too, when you kind of think of yourself as a handy guy, yet come across more and more stuff, you can't even open, don't know what you are looking at, and in the end, can't repair.
This may not be the dumbest thing I’ve ever done.
Once, I ran my motorcycle battery dead trying to start. Putter putter die. Putter die. Crank crank crank. Nothing. Problem - fuel petcock was OFF!
Funny now.
MoKelly
