BoylermanCT
Veteran Member
- Joined
- Apr 1, 2013
- Messages
- 1,513
- Location
- Barkhamsted, CT
- Tractor
- Montana R2844, New Holland TC29D, Hustler X-One
I am looking to install a Chamberlain wall mount garage door opener in my barn. I have two 9x9 sectional metal overhead doors. I am sold on the advantages of the wall mount unit, extra head room, quiet drive etc. but I don't understand how it makes the door close. To open, the drive rotates the door's main shaft which wraps the door cable around the spool and lifts the door up. As my door is installed now, once up, you have to tug gently on the pull rope to get it to come down. The main spring is tensioned so the door stays put half way up. Above half way and the spring wants to pull the door up and below half way the spring wants to let the door close. So if the opener reverses direction and turns the drive shaft the opposite way of opening, why won't the cable simply unwind off the drum? My door is on standard tracks where the door is lying parallel to the floor when fully open. I don't see my door wanting to close unless I completely change the tension of the spring so it is trying to pull down when fully opened which would seem to make the motor work really hard to open the door.
I read through the Chamberlain installation manual and watched their installation videos, but did not see anything to address this. Maybe I am missing something. If anyone has one, can you help me understand how the closing process works so the door starts moving down vs simply unwinding the cable. I figured I would start with the TBN crowd before sitting on hold trying to reach Chamberlain.
