Wall Mount Garage Door Opener - Question for Current Users
/ Wall Mount Garage Door Opener - Question for Current Users #1
BoylermanCT
Barkhamsted, CT
Montana R2844, New Holland TC29D, Hustler X-One
I am looking to install a Chamberlain wall mount garage door opener in my barn. I have two 9x9 sectional metal overhead doors. I am sold on the advantages of the wall mount unit, extra head room, quiet drive etc. but I don't understand how it makes the door close. To open, the drive rotates the door's main shaft which wraps the door cable around the spool and lifts the door up. As my door is installed now, once up, you have to tug gently on the pull rope to get it to come down. The main spring is tensioned so the door stays put half way up. Above half way and the spring wants to pull the door up and below half way the spring wants to let the door close. So if the opener reverses direction and turns the drive shaft the opposite way of opening, why won't the cable simply unwind off the drum? My door is on standard tracks where the door is lying parallel to the floor when fully open. I don't see my door wanting to close unless I completely change the tension of the spring so it is trying to pull down when fully opened which would seem to make the motor work really hard to open the door.
I read through the Chamberlain installation manual and watched their installation videos, but did not see anything to address this. Maybe I am missing something. If anyone has one, can you help me understand how the closing process works so the door starts moving down vs simply unwinding the cable. I figured I would start with the TBN crowd before sitting on hold trying to reach Chamberlain.
/ Wall Mount Garage Door Opener - Question for Current Users #2
I have two LiftMaster 8500 units now, and had one at our previous house. I installed all of them.
If you've ever set the torsion springs on these doors, you know that they are pretty sensitive once you get into the ballpark of proper balance. Add just a little more tension and the door wants to go up on it's own. Take away a little tension and the door will drop on it's own. For closing, all a jackshat opener does is to counteract a teeny bit of the spring torsional tension so that gravity can take over. It's just like if you yourself had taken 1/2 turn off the spring tension. The doors are heavy enough that they don't need much help.
I think you can answer your own question in a convincing matter by putting a pipe wrench on the end of your jackshaft and give it a turn. You'll see the door go down and the cables stay tight. Your muscles are doing what the opener's motor would do, offsetting just a little bit of the spring torsional tension.
/ Wall Mount Garage Door Opener - Question for Current Users #3
By the way, your door and track should not be fully horizontal up top -- there should be a slight slope to the track, and furthermore, the very bottom section of the door should be in the corner of the track and still have some amount of angle. Usually the bottom of the door and bottom wheels sit slightly below the opening header (so you should see about 3-6" of door hanging down into the opening). If the door is going up much past that point or is completely up on the upper section of the track, then you should adjust the stops and maybe re-check the spring tension.
From what you described the spring is set right. Should take light effort to lift the door to about halfway, then the spring should provide gentle counterbalance and help lift the rest of the way but not any sort of acceleration or pull. The door should run into final position gently and not jerk the cables too far past vertical. If the door pulls hard to the stops and/or the cables are being pulled towards horizontal then the door is going too far and/or the springs have too much tension.
/ Wall Mount Garage Door Opener - Question for Current Users #5
I have 2 8500 LiftMaster on 2 - 12 x 10 roll up doors on my shop. I love them. I'm thinking about putting a roll up on my garage.
Thanks S219. The door rails go up two feet above the top of the door opening, so the bottom door panel is still almost vertical and the next panel is at a 45 degree angle and the other 4 panels are on the flat section.
I went out with a pipe wrench and turned the shaft by hand, and the door came down without loosening the cables. I never would have guessed. I may end up raising the rail ends so the horizontal track is not perfectly level. Thanks for your help!
I'm ordering the 8500 openers after Christmas.
/ Wall Mount Garage Door Opener - Question for Current Users #8
I just put 2 of them in (8500's). You might need to back off the springs by 1/4-1/2 turn, but you can certainly give it a try first and see if it works or not. If the cable goes slack then you will need to reduce tension slightly, but your test with the pipe wrench may have already answered that. There is a cable tension monitor and getting it set right is probably the hardest part of the install. I had to shim behind mine with some thin plywood scraps to set the distance from the wall right.
/ Wall Mount Garage Door Opener - Question for Current Users #9
My Liftmaster 8500 stopped this winter - 11 years. I think the door rollers are getting tired and the door won’t slide down the slope like it did new. One hesitation resulted in an hour straightening cables. So now I have a pair of down assists to install on the track ends. Another option would be to add more tilt as I have the room but I opted for the assists.
/ Wall Mount Garage Door Opener - Question for Current Users #10
Thanks MHarryE. I did not think of down assists. Every time the cables came off I would add slope to the tracks, adjust spring tension and limit the opening height. It only happened in the beginning when setting up the doors.
4 Liftmaster/Chamberlain 8500 on 12x14 sectional doors.
I will order the down assists (plunger bumper springs) now and reset the doors to open the full height.
carl
/ Wall Mount Garage Door Opener - Question for Current Users #11
Sounds like everything is OK as-is and you probably don't need to mess with the rails (in fact, usually the door roller brackets are such that the door will still have an incline even if the track is horizontal). As long as some portion of the door is either hanging vertical or at a 45 in the corner, there is plenty of weight to pull down on the cables and keep them under tension. They should never un-spool as long as that is the case.
Years ago with another brand of jackshaft opener (Wayne Dalton "iDrive", since taken off the market because it was junk) I had some boxes block the downward travel of the door and the cable spooled off the drums. It was a trainwreck and dangerous situation to resolve, since the door got crooked in the track and then the rollers started falling out. It's a miracle I didn't get hurt or damage the two cars parked in the garage.
The Chamberlain 8500 openers have a slack sensor -- basically a spring loaded limit switch with a roller that rides on the cable. If for any reason the cable goes partially slack, it will trigger that switch and promptly stop the motor before it goes fully slack. So in the unlikely event that the door stops moving due to an obstruction, the cable won't unspool and you won't encounter the dangerous situation I ran into. Combined I have been running an 8500 (or predecessor) opener for about 20 years and they have been super reliable. I really like the whole principle of how they operate. I'll probably be adding one to my workshop, since I now have an antique car parked in there and use the door a lot more than before.
/ Wall Mount Garage Door Opener - Question for Current Users #12
It's really very simple. When the door opens, the opener has to be pressed for the door to move. If the coulter isn't pressed at that moment, the door can't move on the rail because it simply cannot move in space. A certain height above the fence must be maintained for the colter to work. This height is set by the slack sensor.
This may vary in different types of garage doors, but I think it will work that way in this case. I'm thinking of replacing my garage doors and installing a mechanism like this. Are you satisfied with using it?
I installed the opener today. Went with a Genie instead of Chaimberlain / Liftmaster 8500. Watched some comparisons on YouTube and like the features of the Genie better.
Installation was easy. Everything worked as it should and setting the open and close settings was simple. Very happy with how it went and will be ordering a second one for the other door.
Still have to straighten up some of the cables etc, but love how quiet they are and having a full 12’ of headroom.
/ Wall Mount Garage Door Opener - Question for Current Users #14
If you don’t have one yet install a bumper pusher spring noted by Citydude. Easy to install.
/ Wall Mount Garage Door Opener - Question for Current Users #16
Can't make a choice between Chamberlain and lifmaster. Any thoughts? Would like to talk to both of the customer services and found the liftmaster's here https://liftmaster.pissedconsumer.com/custоmer-service.html. Anyone know how to contact chamberlain? Thanks in advance and have a nice weekend everyone.
/ Wall Mount Garage Door Opener - Question for Current Users #17
I have both, no problems with either, 20+ years.
/ Wall Mount Garage Door Opener - Question for Current Users #18
Now I have a problem with my Chamberlin. We had a weird power outage where the power went off and on for a while at maybe one second intervals, which as you know can wreak havoc on electronics.
I don’t know if that was the cause, because the door opener worked for a while after that, but now the motor runs but the door doesn’t move, and the motion detector light stayed on and wouldn’t go off. Unplugged everything for now, until I can have a closer look. I’m hoping that maybe just the connection to the big rod that goes across the top of the door is not tight enough. Otherwise, it might be big money!
