Walker's F Series Thread
   / Walker's F Series Thread #81
After seeing your success, I went out and found a used F2560 with 72" side discharge deck for $5,000. Newly serviced, new rear tires just mounted, new set of front tires that need to be mounted on the rims. Was almost dark when I got it off the trailer so no pics yet.
Well the mowing deck gearbox seal has basically failed at this point. The gear oil will leak out after about 30 min of use. Way too risky to continue using.
I'm going to do some forums searches and read a few threads before tearing into it. Hopefully there's nothing else weird going on and seals will fox it. I'm guessing if the shaft(s) are smooth then a seal should do the trick. Any advice or links is welcome!
   / Walker's F Series Thread #83
If the majority of it is leaking out then the seal is damaged. If it were just seeping a bit, I would check the vent but a clogged vent won't create that much fluid loss.
It is good that you caught it in time so that hopefully a seal is all it needs but while it is out I would seriously consider bearing replacement.
After a dry summer, there has been a lot of rain lately so my F2690 is getting a lot more exercise with twice weekly mowing.
Rodger
   / Walker's F Series Thread #84
Sorry, can't help much since my RD deck originally had a US made gearbox, which is now obsolete as far as I was able to find out couple of years ago, but I was able to buy couple of ($150) generic 90* spare gearboxes and have been running one of them as a test drive for probably close to 100 hours now.
The original (Superior 211ADF 189 6 Gearbox) is still fine, I just wanted a spare(s).
The original was priced at around $800 or so, however it was no longer available according to dealers.
I am under impression that it may be hard to find alternatives for the gearbox in newer F models - hopefully all you need is couple of seals / bearings.
A used F series popped up on Facebook marketplace in Sioux City Iowa,,,, so tempting, in case anyone is looking for one:
There was a puddle under the deck where it sit all winter.
I took the gearbox off and replaced the lower seal. The bearings were all intact and spun freely, everything looked good and clean from what I could see.
So far so good but I've only used it for about 2 hours so far. Time will tell.
At any rate I now know how to take it apart. I honestly forgot all about the shop manual I had on the shelf... I just started taking it apart. I got it apart but it wasn't per the book. If I remember correctly, the book has you drop the whole lower spindle carrier.
I may pull it completely apart next winter if I'm just looking for something to do. I could have gotten a better look if I had that whole piece out on the bench.
   / Walker's F Series Thread #87
Glad to hear you got the leak repaired - hopefully it will last.
Those are pretty expensive bevel gearboxes, and I have seen only one aftermarket supplier so far so it's well worth the effort to keep an eye on it...
This thing is so awesome, it cuts so good, a joy to operate. New video:
   / Walker's F Series Thread #89
Pretty tall grass & other stuff for a rotary mower like these!
   / Walker's F Series Thread #90
I am now into my second season with my F2690 equipped with the 72" rear discharge and I still love it. I mowed for close to 30 years with my Deere 955 with 72" midmount and the Kubota has pretty much retired the Deere from mowing service so it is mostly used with loader, blade, and rear rotary cutter.
The Kubota hit 69 hours today, the 50 hour service was last month and was a simple process.
Two minor complaints:
1. With the rear discharge deck, you do have to remove the driveshaft to raise and flip it for access. Apparently that wasn't true before the redesign but now the driveshaft interferes when trying to rotate it to the horizontal position. It is only a minor nuisance and I love the rear discharge deck AND the easy access.
I tried out my new All American sharpener today and it took under 20 minutes from getting the Kubota out of its garage to having it ready to mow with freshly sharpened blades. I will pick up another set of blades the next time I am near the dealer so I can keep a sharpened set ready to go like I did with the Deere.
2. With the ROPS folded over, the engine cover can't be raised. Maybe an intentional decision by Kubota to make us less likely to just leave the ROPS folded all of the time :) With the peach and apple tree limbs bowing a bit under load, I folded the ROPS to mow under them and found when I went to do post-mow cleanup that was an issue.
And a very minor annoyance is the spring loaded cover over the gearbox/driveshaft connection. I always use my Stihl Kombitool blower to clean things up after mowing and trying to one hand the blower while holding the cover open isn't great. A bungee cord solved that minor issue.
Overall, maintenance on the Kubota is much easier than the Deere and I really like Kubota's use of angled zerks from the factory where needed.
Rodger
   / Walker's F Series Thread #91
Hint, Coleman's in Kansas City has the best prices and fast shipping on the blades and anti scalp rollers as well. Even better than my local dealer has and that included shipping. I have a side discharge 72 on mine and I like it as well. I call the F series a mowing fool. I mow in low range all the time simply because for me, it's easier, your mileage may be different.
Taking the ROPS completely off this winter. I have the same issue as you do with the hood 'bonnet' I never feel like it's tippy anyway, unlike the ZTR I traded in on it.
   / Walker's F Series Thread #92
… I never feel like it's tippy anyway, unlike the ZTR I traded in on it.
My F3710 being 4” narrower than my ZD1511 feels way more tippier than the Zero
In fact it’s actually scary seeing the upper tire rear up while mowing my bank horizontally.
   / Walker's F Series Thread #93
Rodger
I was able to open my former F-3680 hood with the ROPS angled. I just had to give it a slight lift, then pull the hood up and it would just barely slip under the ROPS.
As most of you know, I sold my F-3680. Just for kicks, I might look for an older model F or a Toro with 4WD to cut one remaining retention basin area a customer of mine has.
I have seen Toros 4WD and 72” deck sell for $5,000 but they may also come with problems.
   / Walker's F Series Thread #94
If anyone has an oldie, but a goodie, let me know.
   / Walker's F Series Thread #95
   / Walker's F Series Thread #96
Thats what I need for “hacker” mowing jobs (tall grasses, steep).
Are those models still in production?
Any weaknesses/downside to them?
I see them on FBM/CL for 5-10K
   / Walker's F Series Thread #97
   / Walker's F Series Thread #98
I have an oldie, but a goodie, 2004 TORO 328D but it is not for sale:
View attachment 878729View attachment 878730View attachment 878731View attachment 878732
The Groundsmaster is one tough machine. I worked a few years for a state park agency after I retired from my construction career. The agency had ton of them. My boss was in charge of procurement and always preferred the Toros over the green and orange machines for mowing duties, if the negotiated state procurement contract allowed.
Simple, heavy duty machines. A tough combination to beat.
Doug
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2014 GMC Savana 3500 Cargo Van (A59230)
2014 GMC Savana...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
