W4 beam load capacity?
/ W4 beam load capacity? #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I'll be building a post frame shop with a steel frame roof so I don't have to use trusses. I'm using a 40' high cube shipping container as one wall and then building the other 3 off of it, planning to end up with a 40 x 40 to start.
Can I use W4x13 for the center support beam? I have them available easily but only in 20' 4" pieces so I'd have to fish a couple together to make the full 40' span. I want clear span underneath so there would be no center support.
Roof will probably be a 3/12 and we don't have snow to worry about so there's no load to speak of, just the roof structure and tin, I just don't want it to sag in the middle. There seem to be some engineers here that really understand beam load capacities so I'm hoping one of you can help.
/ W4 beam load capacity? #2
I don't think a w4x13 is nearly enough beam. You need to figure out your dead load and live load then you can begin to figure out your distributed loading. This will dictate the minimum size of beam needed. Generally deflection or lateral torsional buckling will limit your beam designs. Introducing a connection into the equation really complicates the problem. I would strongly suggest investing the money into an engineer if you want to be sure it will stand. Connection points are a very unique animal and require some more advanced knowledge of figuring out how to transfer the forces.
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
New/Unused 12 Ton Hydraulic Jack (A65583)
New/Unused 12 Ton...
2016 Honda Pioneer5 1000 (A62613)
2016 Honda...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
Aluminum Mermaid (A65583)
Aluminum Mermaid...
