Vintage Ford Remote Valve
/ Vintage Ford Remote Valve #1
Richard Strausbaugh
Ford 641
Can anyone give me more information on this remote valve that fits the hunder and early thousand series tractors. Assuming it came off of a utility loader tractor.
This valve has ALCO stamped on it with four groups of numbers "3-373", "675", "548", and "7/17/5". Would assume the last one is a mfg date.
The valve has four ports labeled as 1 2 3 4. And when I got it, ports 2 and 3 appeared to be being used and 1 and 4 were plugged. In playing with it I can see if you lift the one lever both ports 2 and 3 opens. I am guessing that this are dual action ports and with the level up one is send and one is return, and with the level down they flip and the other one becomes the send.
But the 1 and 4 port on the bottom appear to function different. Do not have it on a tractor yet so can not test. Could those be two SA ports that are designed to work together.. Up pushes oil in port 1 and releases oil in port4, and down reversed it, pushing oil 4 and release it in 1. Not sure can not tell from my off the tractor testing.
Also any idea where I could get replacement parts if needed?
Thanks for any and all feed back.
/ Vintage Ford Remote Valve #2
lotsa people made valves to fit those fords.
with 4 ports I bet it is 2 da valves, and with 2 ports blocked, I would imagine it was being run as both in sa. I have a few single and dual valves.. most of mine can configue 1 valve as sa, an dthe other as da only.. not sure on yours. RickB may know.
soundguy
/ Vintage Ford Remote Valve #3
I've seen only one of those valves. Needed a spring, and some linkage parts. Failed miserably trying to find them :(
/ Vintage Ford Remote Valve #4
I don't think I have seen that valve. If I did, it was unremarkable because it was working and not leaking, I suppose. Sorry.
2005 Nissan Frontier Crew Cab Pickup Truck (A59230)
2005 Nissan...
FRONT MOUNT TANK BRACKET (A60430)
FRONT MOUNT TANK...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
FENCE PANELS (A58214)
