video?
/ video? #1
smilindave
Dayton, Pa
Power Trac 425
I'm considering a cement mixer for my 425 and I thought I saw a video somewhere. Just can't remember. I did a search on here and Pt's web site. Thinking maybe I didn't do a good enough search or its no longer on here. Can someone help a guy out?
/ video? #3
Huh...... I have a Hyd phd that I could make this work on.... I wonder where I could get a pre fabbed barrel,that fits over my 2" receiver. Any ideas?
/ video? #4
It seems simple enough to convert a regular cement mixer to hyd like dfkrug did.
You could also make a bolt pattern frame work to match to your drums studs and just bolt it on.
Don't know how much side forces are there..
/ video?
Thanks JJ for the links. I thought for sure that Power Trac had one out there. I also am thinking of making my own using the post hole digger motor. Its one of those attachments I don't use that often.
/ video? #6
This guy had this power trac listed in the used section on the power trac website a while back. At 8:00 it shows the cement mixer he made using the post hole digger.
[ame=http://www.youtube.com/watch?v=0_YCbXlmeV0&feature=related]mm power trac - YouTube[/ame]
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
Case TV380 (A62177)
Case TV380 (A62177)
