VFD-Need Help Identifying Terminals
/ VFD-Need Help Identifying Terminals
Page 5-2 shows some components on the terminals in question although I don't see the one marked (/) in the first post picture.
I doubt that any additional braking resistor will be needed on this 1.0 HP lathe application. I'm guessing that deceleration rate can be adjusted to make thread die and tap die reversals quick enough. Single point threading up to a shoulder can require a quick stop if the half nut isn't operated for each pass.
/ VFD-Need Help Identifying Terminals #13
Do not hook anything to the dc bus and make sure it is good and discharged before you touch it. Once the charge light goes out your ok to touch
So, you're saying that the terminals shown in post no. 1 are the dc bus?
/ VFD-Need Help Identifying Terminals #15
Yes , ac voltage is marked l1,l2,l3 on incoming and u,v,w on outputs. +,- are tue dc bus.
Kivel trailer mover attachment (A61567)
Kivel trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
CFG H15R (A60463)
CFG H15R (A60463)
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
