VERY expensive beet juice!
/ VERY expensive beet juice!
Any concerns with WW fluid reacting negatively to rubber or tire patches / adhesives used in tire patches in the case of a future flat?
If I can source it for a decent price then it sounds like a decent way to go.
/ VERY expensive beet juice! #22
I have done all my tractors myself using my 35 gallon pull behind lawn sprayer, a 10' length of garden hose, and a $10 adapter from Napa. Last tractor I did had 9.5x24 R1's so I got a 55 gallon drum of -20 WWF from my local oil supplier. It was only $38 in about 2009 or 2010, can not remember when.
Anyway, $40 and a hour of my time I added about 22 gallons to each wheel if I remember right and saved the rest for my cars in milk jugs. Still have 5 or so gallons left.
Chris
If I can source it for a decent price then it sounds like it may be the way to go.
/ VERY expensive beet juice! #24
I have included a link on WW fluid. I see nothing that negative about WW fluid. I have Rimguard in my tires.Iowa Farm Equipment -- Rim Guard
/ VERY expensive beet juice! #25
None that I have heard. And.....a big advantage is that you can plug a tubeless tire yourself.
I'd make sure you get the -30 (or more?) WW Juice for Canada. What I read earlier was that it was hard to beat the Marts for prices on WW juice.....and the gallon jugs are easier to handle (but I have never shopped for it).
/ VERY expensive beet juice! #27
Anyone ever just put in a crop of beets and get a juicer?
I'm thinking about it. When we seem to be willing to pay $1.00 for 16oz. of bottled water I doubt that fluids are going to get any cheaper. We fuss about high gas prices and then spend $8.00 a gallon for bottled water.
/ VERY expensive beet juice! #28
I had my Bobcat dealer save all the Propylene/Glycol engine antifreeze they removed over a few months of engine and radiator repairs. Now have 55 gl drum of it, tires will hold 24 gl. each. No charge for the anti-freeze because they have to pay disposal fee to get rid of it.
/ VERY expensive beet juice! #29
Here we go again. :confused2::thumbdown::confused3::mur:
/ VERY expensive beet juice! #30
Geez, that's a bargain............A 16 0z. bottle of water around here is 1.25 to 1.75 depending on the machine.
/ VERY expensive beet juice! #31
I honestly could care less about the reaction of WWF and tire patches.(no offense intended).............
But if it leaks and kills my crops, and/or keeps next years crops from producing......and/or kills and/or harms my pets or wildlife in any way.............yes............I have a problem!
EDIT: And as I said earlier, Rimguard claims that it can stop leaks, in tubeless tires. And after seeing firsthand what Rimguard does...............I believe it.
But with all the above said.............I have no info on the 'beet juice' that has been made available to residents of Canada.............
You are on your own to do the investigative research of the product.
/ VERY expensive beet juice! #32
One plus for weights is that they won't ever pour out onto the ground if you puncture a tire.
I've been thinking about what makes beet juice better at resisting freezing and have come to the conclusion that it is probably a colligative property resulting from the sugar content. Wonder if mixing up a syrup of plain old cane sugar and water would behave the same?
I've just assigned myself a new experiment for the winter...I'm going to mix up a saturated gallon of sugar water and leave it setting on the deck. If it doesn't freeze then I've just invented my new tire fluid!
You must have taken a nappy in HS chem class, eh? Google "freezing point depression of ionic solutions".
-30 f Windshield Washer Anti-freeze is about $3.00 per gallon....and would appear to the the lowest cost DIY alternative (without going to CC). One of the Mart's is likely the cheapest place to buy it. It's not as heavy as cc or beet juice....but it is lower cost and weighs about as much as the RV antifreeze. A flat tire does not pollute like others....IMO.
I would not dillute the RV antifreeze if you live in the north country.....and it costs more than RimGuard around here. No advantage in it for ballast....as I see it.
I run Rim-guard. No regrets. :)
The cheapest solution is to go to the junk yard and get used antifreeze. Typically will be mixed to -30F or lower and will be about $1 a gallon in 50 gal drums.
/ VERY expensive beet juice! #33
That is the cheapest solution, but is it the safest for livestock/crops?
EDIT: and one should keep in mind, that used antifreeze...........can become quite corrosive to metals after time.
Ethylene Glycol - automotive antifreeze - is out for me even though it would work - because of the risks it poses to pets and livestock. The only anti freeze I would consider is Propylene Glycol (RV) because it is not toxic I am told. I'm looking to look for it in concentrated form.
/ VERY expensive beet juice! #35
Nope, no 'nappy' for me. That's why I understand that colligative properties depend only on the number of particles of solute and not their chemical properties.
You are correct that an ionic compound of relatively low molecular weight is more effective because it puts more particles into solution per mass unit, but that doesn't mean that whole nonionic molecules don't have a similar but less pronounced effect. But now that I think about it I realize I've already proven myself wrong with an experiment done in my own kitchen. Flavored ice pops are loaded with sucrose and they freeze at normal household freezer temps, so sucrose must be too big a molecule to build up a large particle count before it saturates.
So I wonder what the chemical is in beet juice that makes it effective and yet non-corrosive? And I wonder what nonionic, water soluble compound of low molecular weight can be bought cheaply in large quantities?
/ VERY expensive beet juice! #36
just like you can buy EG radiator AF, you can also buy PG radiator AF, not just the rv holding tank stuff either.. the real concentrate, not a premix, the stuff made for the rad.
for instance.. prestone sells 'lowtox' as it's form of PG af for the radiator.. etc.
soundguy
/ VERY expensive beet juice! #37
II'm going to be adding some sort of ballast to the wheels / tires - either weights or Rim Guard. I haven't found a source for WWF yet. I guess RV antifreeze might be an option.
My dealer loaded my rear tires with RV anti-freeze for free.
I like the way they ride. It is potable and non-corrosive.
David
/ VERY expensive beet juice! #38
All these posts, and NO mention of that old classic- calcium chloride. Farmers have been using that since rubber tires replaced steel. Is corrosion really that big a problem? (they keep their machines for decades)
Also, most farm tractors around here have weights, front and back, but they are tillage machines.
/ VERY expensive beet juice! #39
" Rim Guard"...........and "Rimguard", are two totally different products.
OK....so what's the difference? I didn't know this, and couldn't find any distinction between the two on the web.
soundguy
Neat. I'll start looking.
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
Frontier Forks (A64126)
Frontier Forks...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
(APPROX. 30) WOOD VEGETABLE BINS (A64276)
(APPROX. 30) WOOD...
