Utility trailer for behind tractor
/ Utility trailer for behind tractor #1
teeravis1
Central Wisconsin
JD 4044R
I am looking at getting this 2 ton tandem floating axle utility trailer from country manufacturing for behind my b3030 Kubota for firewood, leaves, and anything else I can use it for:
http://www.countrymanufacturing.com/wagons.htm
Does anyone know of anyone with it or something similar and how they like it? I also looked at the Muts utility trailer and boski trailers also but liked this the best. Your thoughts would appreciated with the pros and cons you see with what I am looking at. - thanks
/ Utility trailer for behind tractor #2
Trying to save you some money.I ascertain that you already have a three point trailer hitch.I have a Kubota L4400. I bought a trailer made from a full size dodge pickup truck for $175.00. It is in perfect shape-no rust with functioning tailgate. I also bought a 5x8 trailer body that was 4 months old for $300.00. I installed 4 foot sides with removable tailgate for an additional $60.00. One trailer is 1 7/8 ball and the ther is 2 inch ball. Both are titled and registered, have farm use tags. I use these two trailers for everything on the farm. I use my FEL to drop stumps, debris and everything else and transport the before.mentioned to my burnpile. I pick up various other farm supplies with these trailers along with my Silerado. In NC you can utilize trailers with farm tags for farm use;etc.with limited mileage. I even haul my neighbrs trash along with ours to the county dump. We have two larger and heavier trailers but I use these the most.We live on 30+acres in the piedmont region of NC
/ Utility trailer for behind tractor #3
I have a trailer like the model 7200. Sort of like a small hay wagon. Very hand and built pretty good. I think I got mine though Northern Tool for about $200 delivered 10 years ago or so.
Chris
/ Utility trailer for behind tractor #4
The 2 ton looks pretty similar to a hay wagon. Down here, you can pick up a good used hay wagon for somewhere around $500.00.
/ Utility trailer for behind tractor #5
CMI Utility Wagons & Trailers for atv and lawn and garden.
I have the same wagon with hydraulic dump. Built a pickup leaf loader into the front end of it. Pull it behind a B3030. I'll look for some pictures if that helps. The only issue I have is with the leaf loader between the tractor and the wagon I wanted more space. I use a set of 3 pt hitch locks from TSC to keep the wagon tounge connected to the tool bar from lifting when the trailer is dumped. If the wagon is connected to the B3030 drawbar this is not a problem.
I have a Kubota rear remote on the B3030 that I use to drive the dump cyl.
I have had the trailer for 6 years no issues.
/ Utility trailer for behind tractor #6
Wagon style axles for tractors, tandem style axles for trucks. With a wagon, you can unhook to use the FEL, etc, then hitch up and go without having to resort to tongue and corner jacks.
/ Utility trailer for behind tractor #7
I bought the "2ton" tandem trailer from Norther tool and all I can say is I ended up with some usable scrap metal. There is no way that trailer should have been rated for 2 ton. I didn't even have 1500lbs{not even 1 ton} in it when the hinges buckled like soft playdough. I wrote to them and explained what happened and also suggested this could be a very unsafe add for that trailer. Lucky when it buckled under the lite loud no one was close enough to get hurt.
Not real sure about the one you're checking out but just wanted to write be carefull of these so called handling louds of certain trailers manufacturers.
/ Utility trailer for behind tractor #8
maybee it's a rating like electric motors.. IE.. 'peak' pounds :)
It's a tad spendy.. hope it's up to it's ratings for theat price. too bad it don't come with that hyd cyl and hosing for that price.. aetc..
soundguy
/ Utility trailer for behind tractor #9
Northern tool imports a cheap copy of the Country Manufacturing trailers and wagons now. I have had the Country 2 ton trailer for 6-7 years now and other than repainting the frame, it is a solid unit.
I highly recommend their equipment.
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Adams Nurse Trailer Tank (A63118)
Adams Nurse...
More info coming soon (A61569)
More info coming...
New Holland 354 Feed Grinder (A64047)
New Holland 354...
2020 MACK GRANITE GU713 DUMP TRUCK (A59910)
2020 MACK GRANITE...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
