Using bucket as work platform.
/ Using bucket as work platform. #231
/ Using bucket as work platform. #234
It's in your user control panel.
soundguy
/ Using bucket as work platform. #236
While digging out a truck, I blew a bucket cylinder hose. I was working the little tractor hard, and the bucket curl let go. I don't remember it being a drop, as it was close to the ground, it just wouldn't respond. The hose actually completely seperated, so it pumped a good amount of fluid out. I saw the fluid stream and shut down the tractor.
So I suppose its perfectly possible that a hose could blow and either the bucket dumps you out or the boom lowers you. But from what I have seen it moves slow enough for the person to be able to react appropriately.
I won't fear a hydraulic failure but more importantly a tire failure. I was using forks and a palette to load 45' trailers with our equipment last fall when I must have hit a nail with the front right tire. I had raised the load and set the edge of the palette on the edge of the open trailer, climbed in and began unloading the palette. When I was done, I hopped back in the tractor, started it up and thankfully lifted before backing up. As I lifted the right tire gave way and the palette slid into the trailer wall. Had I backed up, I think it would have tipped over.
/ Using bucket as work platform. #237
Here is a platform I used to clean my vinyl siding at my last house.
/ Using bucket as work platform. #238
Unnamed TBN members caught in the act of using their FEL as a work platform...:rolleyes:
It could have occured in SC...I think the tractor is orange...;)
Well, that's not me in THAT picture. But I am in SC, I do have an orange tractor and I do use my bucket as a work platform. Not often and with great caution and usually at pretty low levels.
Could not have built my tractor shed without it.
/ Using bucket as work platform. #240
Nice lookin barn..
soundguy
TANK MANIFOLD (A58214)
CASE TV450B SKID STEER (A62129)
CASE TV450B SKID...
large capacity skid steer bucket (A56857)
large capacity...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Caterpillar Quick Attach Forks (A60463)
Caterpillar Quick...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
